Today I installed a DEFI BF series boost gauge and associated Link II computer in my R32 GTS-T.
I got it all working but then the readings it gave seem incorrect. I put it in purely for looks. My car has never been boosted amd is 100%, stock other than:
1. X-Force 3" Turbo Back Exhaust with high flowed cat ( i got is as an all in one exhaust )
2. Simota Pod filter
Thats it.
The problem is that the boost gauge said that my car is running at 0.82 Bar which is about 12psi....
Surely that reading cannot be right? Anyone have any suggestions or similar experiences?
https://www.sau.com.au/forums/topic/165627-boost-gauge/
Well that factory gauge I dont know what it is measured it, but it only ever goes so high, even if you did boost your car it cant go higher on the factory gauge.
I noticed on the way home tonight though, when factory gauge was on exactly " 0 " the one I installed was reading just over 0.1 bar or about 2 psi. So they dont seem to agree.... :thumbsup:
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3069489
10psi stock r32
7psi stock r33
r32 has greater boost.
With an exhaust you will have boost leak so it may jump up to 11psi.
Im running stock boost, dyno shows it going up to 12 and then dropping down to 10~
mods are exhaust, smic and pod.
Cheers
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3077607
10psi stock r32
7psi stock r33
Cheers
Boost leak? so does that mean its not actually running 12psi? Cause my mate boosts his 32, his gauge reads 12.5 psi at that point and his car FLYS!!! Im confused and worried aobut my car now. I really think i need to take it on a dyno...
I was thinking maybe one day I would boost it so id have more power but if its actually running 12psi now then its pretty much at the limit now?....
Edited by r32line
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3078157
10psi stock r32
7psi stock r33
where did u get that info from?
why is ther so much confusion about the stock boost of r32's? its freggin annoying, some pll say 7psi, some say 10psi...
has anyone got a link, a scan of a nissan magazine, something that says "the stock boost for the r32 is ___"????
cause id really like to know wat it ACTUALLY is stock
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3078202
mate its 10psi. If you put your stock r32 onto a dyno it will show you 10psi.
10psi is the standard of R32 GTST's
Boost will slightly increase due to a free flowing exhaust and a new intercooler.
Ask a decent mechanic, he will say the same thing.
The RB20 one is stock at 10psi, and the RB25 one is stock at 7psi.
http://www.project32.net/tutorials.php
- Patrick
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3078317
Again, What is boost leak specifically??
And if my car is running 12 psi that means I can't boost it cause it is already at its limit?? If so its a bit disapointing...
Would a high flowed r33 turbo running 12psi give much more power over what I have currently? (without front mount)
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3080254
I started stock - 10psi
Xforce + front mount - no noticeable rise from 10psi
Dr Drift remap set 13psi - 13psi as it should be :yes:
r32line it sounds like you have a faulty gauge and with a stock ecu and no boost controller i don't know how your boost could actually be up at 12psi. simply getting a boost controller and putting an extra 2 psi through it may not give you very good gains. rylan (foznice) did dyno runs increasing the boost from 10psi onwards and found the power decreased at 12 due to a range of things which i can't remember. what i gather is that +boost without tuning to the ecu is not as effective as a full tune, obviously. go get a remap with sam, you shouldn't have trouble getting 150kw+ with 12 or 13psi. you'll need a few supporting mods though - fuel and cooling.
I suggest a thick aftermarket side mount cooler. they're good for many reasons.
ps. watch the road when on full boost :)
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3080536
Dr Drift remap set 13psi - 13psi as it should be :)
Yeah thats what i thought. Is there any way to reliably measure boost. Like if i was getting it dynoed/tuned can they connect something to the engine bay and get a reading of boost? Surely there is....
Edited by r32line
https://www.sau.com.au/forums/topic/165627-boost-gauge/#findComment-3080835
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
