Put it this way... mine is a waste of money... looks good, but thats about it. It never stands steady to be ready when driving so no point of it. Problem is the ECU continusously readjusts itself all the time and is the reason why the signal is constantly modifed and the lights bounce around so much.
A/F meters are useless when ECU is in closed loop,but the moment you step on it, the meter should give stable reading.Run it on the dyno against a good A/F meter and maybe mark with texta different readings on the gauge itself.Otherwise its too generic with its Lean/stoich/Reach positions.
When cruising ( in closed loop mode) it is meant to cycle from rich to lean. That indicates that your oxy sensor is working properly.
When gunning it ( open loop) it should read rich.
The middle of the gauge is stoic (14.7:1). Only thing is, because nearly all factory oxy sensors are only narrow band, they can't tell the difference between a little lean and mega lean. Wheres proper dyno air/fuel gauges are wide band and measure from 10:1 to about 20:1 or so.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
