  • Replies 132
ive been receiving emails, at least these last two. site was down for a bit, maybe you didnt get a few (or any?) since then. check out feedback forum and see if anyone else having issues with it
ROM dumping = downloading rom contents via consult (often used when you want to modify ECU with a daughterboars so that you can edit your fuel/timing maps, remove speed limits and such). consult itself is read only, cant remap your ecu with it or make any permanent changes
check out this thread: http://www.skylinesaustralia.com/forums/in...howtopic=143835
no, no problems with r33, so long as whats covered in main post is the case (ie u have stock computer, not aftermarket, havent butchered wiring or done a engine transplant and messed up consult wiring etc).
note: all interfaces are accounted for! (doing this on 3 other forums, which together have covered all available interfaces)
additional people can only get one if someone already on the list pulls out.
since we got close (but not over) the 20+ ($55) threshold:
1) anyone who's donated to SAU will get the interface for $55 incl postage.
2) anyone who hasnt donated to SAU will get the interface for $60 incl postage. ill donate $2 on behalf of each of these people (who havent donated)
note: those who've requested a USB/serial converter, will get their cable and converter after (later than) others, if i dont have time to get the usb/serial cables done as soon as the cables (which my brother will most likely be doing)
here's some pics. can see the bags of pcb's i just received back from manufacturer today. have a few more parts coming in next week. each cable has two pcb's which "stack" on top of each other inside the connector (left one goes on top of right one as shown just above the two sets).
ive contacted first 2 people for payment.
more will follow in next few days
Payment Sent via Bank Account. Hopefully won't take the normal 2 days otherwise it will be that at the most.
Drew.
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
