sorry theres already plenty of reserves - adding anyone else would be pointless as its extremely unlikely there will be enough for you (ie youd need 6 people to pull out)
  • Replies 132
3 more people have been contacted yesterday (and first post updated) as their's are made and ready. next 2 on list might be done today. remaining ones after that probably wont be done till weekend of jun 23.
with a bit over 3 weeks left in the degree, there's no way im giving up now :D
not much chance of making a living out of it, id do better on the centrelink payroll
assembly my end takes about 30 minutes, another 15 minutes to do a full rom dump to test it. all the SMD assembly was done by PCB manufacturer, fortunately.
1) there is one cable + usb available until 5pm tomorrow. pay via paypal (and include your postal address) to [email protected] or use this link if you dont have a paypal account but have CC. post in here before you do so no one else pays for it after you. $82 if you dont have "has made a donation" icon under your name, $77 if you do. add $3 if you want express post.
I'll take it.
USB converter for sale, $20! :action-smiley-069:
cool, taken. edited that out of my post so no one tries to collect again
if u dont want the usb, ill hang onto it and send u $20 with the cable?
btw ur main paypal address listed with paypal doesnt have postcode (but one u put in notes did)
that would be great, Pete.. appreciate it :)
I figured if someone else wanted it I'd tell them to pay you and then say put the 20 bucks as a donation on my behalf but it looks like the donation method is all automated so I'll put it through my control panel instead. Less chance of a cock-up that way!
are you kidding me?
wouldnt you go through the reserve list sequentially to find a buyer? Man i really need this cable its costing me 100bucks a week to run my 9.5:1 fuel loving car.
the people are on the reserve list to cover for people on the list. ie, the only way people on the reserve list would normally get one is if someone on the main list decided they no longer want one.
this cable (or more accurately, the one that will replace it) is from the few cables i have left over that arent allocated to any of the different group buys im doing. it could have quite as easily gone to someone on another forum...that it went to someone from here just means the more chance others on the reserve list will get one (since theres now one less person there).
so, everyone on the main list will still get one, and if they pull out, assuming theres no sudden increase of dud cables (with manufacturing defects), the people on reserve list, in order (assuming they pay within specified time), will get it.
if i asked every person in turn, and waited a few days for them to reply, itd be christmas already!
there's no obligation for you to get one here...i havent taken any money, and it wont inconvenience me if anyone pulls out (so long as they tell me) - if you're in a hurry, you can get a serial cable from blazt.biz for around $103AU delivered, or USB cable for $122AU delivered. particularly for those towards end of the reserve list, since its not that likely that everyone in the main list would pull out to mean there's enough cables for everyone on reserve list.
Hi Pete,
I have followed the instructions on your website, and now have the USB key taped to my buttocks. However, it is uncomfortable when I sit down. Can you address this in a future release?
Thanks
P.S. will try it out tonight :)
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
