  • Replies 132
Hi Pete,
I have followed the instructions on your website, and now have the USB key taped to my buttocks. However, it is uncomfortable when I sit down. Can you address this in a future release?
Thanks
P.S. will try it out tonight :(
You just have to get everything i have dont ya Geoff :)
Recieved my cable and usb yesterday, very happy, will try to give it a workout tonight or over the weekend. Thanks NewKleer.
Regards
Paul
cool, thats all for the moment, might get to make some more next weekend, if my arms havent fallen off from nonstop typing of my thesis until then!
Peter
for people with usb converters who want TECU to work, ive added this to bottom of readme page:
Important: TECU is assy with any COM port other than COM1 and sometimes COM2.
To have any chance of it working with USB/Serial, you need to force COM port to COM1 or COM2 (whichever isnt in use):
1) Find "USB Serial Port (COMX)" in device manager (see above to find this)
2) Right Click, Properties -> Port settings -> Advanced -> Change port number on dropdown.
3) It will say its in use, but if u know it isnt (ie u dont have modem or bluetooth or anything there) then just confirm/continue/ok etc.
4) Open TECU, on main startup screen it where it says "Com Port:1" in bottom left corner - double click this to change to COM2 if you set converter to COM2.
Is there any chance of getting one now? I see there is a reserved list, could I be added to that (though can't see why ppl wouldnt take it, great price!)
Cheers
back at post #81 at least i stopped adding reserves cause its unlikely anymore than those there (and then maybe not all of them) will get one. but if somehow more are available or lots pull out, ive got the order that people have posted in here as reference. basically anyone thats not on the list shouldnt wait around for one if they need one, cause its unlikely you'll end up getting one.
hi pete
just tried this out it connects up ok with ecu talk but the gages don't work
when trying to change com port on the tecu it comes up with error opening com.dat file or error opening com port, i press ok then it opens up, i tried double clicking where it says come port in the lower left corner and comes up run time error 8002 invalid port number and then closes.
can you help i am also using vista 32
cheers mitch
other people have commented that ecutalk doesnt work with vista
im guessing by the sounds of things, tecu doesnt either? (you set it to COM2 i assume)
ill have a .net 2.0 version of ecutalk in a month or two which may work better with vista. when i get a new pc setup by end of month ill try dual boot etc with vista so i can try and make sure ecutalk works with it.
tried calumsult? try conzult_free and nissan datascan (can use the dash without buying it)
http://202.43.226.57/NissanDataScan1_52.zip
http://300zx-twinturbo.com/conzult/software/free_conzult.exe
haven't tried either so will do. and no, how do you set to com 2 not really that great with computers
try srtalk
http://www.zcontrol.net/Default.asp
also datalog dyno but needs a few things installed:
http://www.neoed.servaus.net/DatalogDyno.htm
or obdscantech (free version has popups every 10s)
http://obdscantech.cjb.net/
cables working good and looks the piece. managed to get nissan data scan and works fine with vista tried it out today but will give it a better test tomorrow when i have more time
cheers Mitch
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
