MoogLe Posted April 25, 2007 Share Posted April 25, 2007 interested. will this work with any serial to usb coverters Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3074343 Share on other sites More sharing options...
NewKleer Posted April 25, 2007 Author Share Posted April 25, 2007 Hey wanted to ask,As they come in serial if we have a serial to usb adapter already will that work? Or do we require to purchase the usb adapter from you? nearly any usb/serial converter will work, so its likely the one u have will be fine...no special requirements are needed (in fact the ones i have are much simpler than normal ones since you only need to use 3 of the 9 pins). one with a FTDI chip will work best, but my suggestion would be to try the one you've got, and you can always get one from me later on (subject to availability) if it doesnt work. if i run out of stock, ill track down the cheapest one from elsewhere that will work (theres some on uk ebay, and on a US site) Does this work on a R33 GTR RB26DETT engine? and also, does this work on a R34 GTT RB25DET? (on standard ECUs) if so, i am interested yes and yes, ive added u to the list. RB26 even support a lot more sensors than most other motors do, which is a bonus Hey,I've got an R32 GTS-T. The build date is 10/1989. I've checked my car and it's got the consult port. However you said "find your 23710-xxxxx part number." What part number are you referring too? Also is this a DIY kit or pre-assembled? if its got the consult port it's almost certainly ok. just checked, and its 9/89 that was the transition month. i think one ecu model that i think supports consult started 8/89. which means i think all 10/89+ will support it, and only few in 9/89 and 8/89 will. the part number is the number on the ecu. if its too hard to get to (passenger kickpanel), i can always accept return (minus postage costs) within say a week if you find it doesnt work on your car. i dont think ive heard of a confirmed case where a car came from factory with a consult port, but not an ecu that supports consult, so you should be fine! its preassembled, plug and play. the only DIY bit is plugging it in and running the software Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3074370 Share on other sites More sharing options...
mrgilly Posted April 26, 2007 Share Posted April 26, 2007 slightly of-topic - does ecutalk work on vista? having no luck with it at the moment... finds the com port and just sits there 'not responding'... Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3075859 Share on other sites More sharing options...
NewKleer Posted April 26, 2007 Author Share Posted April 26, 2007 good question...i havent personally tried it...im sure vista will have messed up something to make it not work so u choose the com1 (or whatever) from dropdown, and then it hangs? does anything else change in between? does the display gauges button's text change to say "Connect on port: COMx..."? Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3076121 Share on other sites More sharing options...
GTI16v Posted April 26, 2007 Share Posted April 26, 2007 Put me down for one with usb converter if availible. Regards Paul Holdom 0402325786 Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3076495 Share on other sites More sharing options...
Toasty Posted April 26, 2007 Share Posted April 26, 2007 can you add me to the list, with the usb connector as well. thanks aaron Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3076696 Share on other sites More sharing options...
heller44 Posted April 26, 2007 Share Posted April 26, 2007 I'm a definate on this, just let me know when to pay and its all good. Damn nice of you to make these on your own time for us. James. Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3077164 Share on other sites More sharing options...
NewKleer Posted April 26, 2007 Author Share Posted April 26, 2007 changed u to confirmed also default cable length will be 200cm (as this will make it easier to route behind dash and come out the glove box and reach passenger seat) Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3077227 Share on other sites More sharing options...
mrgilly Posted April 26, 2007 Share Posted April 26, 2007 good question...i havent personally tried it...im sure vista will have messed up something to make it not workso u choose the com1 (or whatever) from dropdown, and then it hangs? does anything else change in between? does the display gauges button's text change to say "Connect on port: COMx..."? Choose COM3 Text says "Connect on port: COM3" tick tock tick tock Give it about 40 seconds (on the shitty work laptop) and it says 'Not Responding...' and the shittiness ensues! Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3077844 Share on other sites More sharing options...
lanky71 Posted April 26, 2007 Share Posted April 26, 2007 changed u to confirmedalso default cable length will be 200cm (as this will make it easier to route behind dash and come out the glove box and reach passenger seat) Nice. Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3077867 Share on other sites More sharing options...
NewKleer Posted April 26, 2007 Author Share Posted April 26, 2007 u sure com3 is right? also what .net framework version and updates have u got installed? (if you know). got all windows updates applied? id probably need to get vista installed to work out what the issue is. maybe have a try of all previous versions on the site and see if any work, or see where the others fail at. Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3077884 Share on other sites More sharing options...
The Milf Guy Posted April 27, 2007 Share Posted April 27, 2007 Im in Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3079978 Share on other sites More sharing options...
NewKleer Posted April 30, 2007 Author Share Posted April 30, 2007 parts have been received by the place doing board manufacture/assembly, still looking at either side of the weekend of 12-13 May for when boards are received, then a couple days from then for when first interfaces will be available (need the cable/connector assembled) Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3084413 Share on other sites More sharing options...
mrgilly Posted April 30, 2007 Share Posted April 30, 2007 u sure com3 is right? also what .net framework version and updates have u got installed? (if you know). got all windows updates applied?id probably need to get vista installed to work out what the issue is. maybe have a try of all previous versions on the site and see if any work, or see where the others fail at. Brand new built Vista laptop from 2nd week April - v1.1 .Net framework. Not really too worried now, gave the cable back to it's owner so I never got to run the diags anyone on westside of Bris who's willing to let me borrow theirs for an afternoon when I get my XP laptop back I'd be hugely grateful! Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3086373 Share on other sites More sharing options...
whiter31gxe Posted May 5, 2007 Share Posted May 5, 2007 I'll have one + usb adapter. Thanks Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3101049 Share on other sites More sharing options...
vitz_n1 Posted May 9, 2007 Share Posted May 9, 2007 lock me in!! confirmed Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3105139 Share on other sites More sharing options...
NewKleer Posted May 9, 2007 Author Share Posted May 9, 2007 just got confirmation the boards are being sent out from manufacturer. so should arrive friday, which will allow assembly to start on weekend. so the expected May 14 (Monday) start date will be when I will start contacting people for payment (subject of course to there being no errors/problems with boards, wont know till i get them and test it out) number of people confirmed by 9AM on Monday will determine price. if we subsequently go over 20 people (but not before 9am monday), SAU will get $5/interface sold, which somewhat make up for all of those who havent yet donated! Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3105272 Share on other sites More sharing options...
mr moo Posted May 9, 2007 Share Posted May 9, 2007 I'll take one with the serial port but I'm running windows vista. will this work as the guy before said he was having problems with his. Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3107390 Share on other sites More sharing options...
Howie Posted May 9, 2007 Share Posted May 9, 2007 (edited) Same deal here.. can someone confirm vista ultimate 64 compatibility? If it works, i'm in. Edited May 9, 2007 by Howie Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3107394 Share on other sites More sharing options...
NewKleer Posted May 9, 2007 Author Share Posted May 9, 2007 well the interface itself will be compatible, but who knows what software works on vista yet? someones already reported ecutalk doesnt for them, so id say theres a reasonable chance it wont work for anyone on vista. id imagine "some" consult software may work, which that is, who knows. so im afraid youll have to decide yourself on that. worse-case scenario that nothing works, i should have a compatible ecutalk version by say, end of july? also: Software - will NOT be provided on a cd - can be download from here note the change there - CD's will not be provided, as this would add a $4 or something to shipping as it would no longer be classed as a "letter" but a "parcel" Link to comment https://www.sau.com.au/forums/topic/165668-ecutalk-consult-interface/page/2/#findComment-3107409 Share on other sites More sharing options...
