also the figures different dynos give can be different.
your guys dyno could be reading high thats why alot of the guys who came to the vic sdu dyno day said thier cars were making 180-190 rwkw on this dyno then they come to our dyno day and only make 140-150.
if the sydney guys have a dyno day then you can compare.
also the air /fuel ratios are important.
ask yourmechanic if he has a reading.
meggala
Guest INASNT
any dyno operator can have your reading 500kw@wheels if they wanted to! i think when u got your car dynoed the first time they bull****ted u man!!
especially with stock comp and rich a/f ratios its impossible!
A guy with a r33 brought his dyno chart to the last melbourne dyno day, after he got his unichip done saying 194kw@wheels. but when he got it dynoed at the day he got 155kw@wheels!
:uh-huh:
Guest INASNT
Originally posted by turbomad
Yes my so called Unichip tune wasn't actually that in tune was it, however he will be fixing it this Sat, and if he can't for some reason then I'll get my money back. So I might be back to check up on his work.
what did the guy have to say when u showed him the graph from the SAU dyno day? did u ask him where your extra 40rwkw's had gone?
As I don't live in Melb I haven't shown him yet, he assured me that there's no way he would have left the A/F ratio at 10:1, so believe me come Sat I'll be sticking around watching his every move making sure he gets it right this time.
Guest INASNT
y dont u get a s-afc or power fc instead of the unichip?
S-AFC - Only intercepts & allows fuel map changes, it doesn't do timing as per the PFC or UC.
Power FC - Costly even @ $1200 for the Power FC add ~$400 for tuning, compare this to a Unichip $1100 fitted & tuned (this is what I paid). Without a doubt the PFC is the better option as reflected by the higher price.
Unichip - IF, & it's a big IF! The UC is correctly installed & tuned then it WILL provide repeatable rwkw gains. My Unichip was able to provide tuning for over 215rwkw (this kind of figure was repeatable on more than one dyno) I also managed the 1/4 time in my sig' with the UC running the show. The power curve & A/FR's were both very smooth & consistent.
BUT...... It took a good tuner who was familiar with both the UC & the RB25DET to get the results! The original installer did a very poor effort @ tuning it. Even the best ECU isn't much good if it's poorly tuned.
Once you start aiming for over 220rwkw the UC "may" have trouble overcoming the stock ECU's AFM over voltage timing retard. This is the exact reason I decided to get the LT12 Microtech, however it "may" be possible to make 220+rwkw with the UC & get a decent power curve, I just wasn’t interested in stuffing around trying to find out!
I think people shouldn't take their dyno reading to personally. A dyno is to tune the car. I've seen some cars sive different reading on the same dyno's.
My one had about 160kw at the rear at Hills and 180kw on 4 wheels on croydon's dyno. :confused:
Yes as Whatisname said it all comes down to cost, I paid $500 for the Unichip and $300 for the so called tune! Now with the SAFC I'd still have to add an ITC to get the same tuning features as the Unichip, which would throw it way over the $800 mark. Now that I've got the Unichip I'll try and get it right, if I can't then sure I'd consider an SAFC, time will tell.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
