lol dont do that, though it would be hilarious....a better question either would have been....how much boost can i run with 'x' mods, or whats the highest kw the stock injectors can take. your next upgrade is afm and injectors
no i meant 78psi
i say this because PSI is pointless in comparison for this sort of thing. it means absolutely nothing.
PSI is only relevative to the compressor you are using. if he tried to run 14psi on a GT40 then the stock injectors have no hope.
if he tried 14psi on the stock turbocharger then its fine. so 78psi on the stock turbo is probably fine for stock injectors.
it wont flow any useful air past 12psi anyway so the other 66psi is just extra heat and nothing more.
so paulr33... im running 10psi on a GT30R on stock injectors. safe?
depends on the compressor model you are using
the compressor map would give you the true answer to this
but a 30R will flow quiet a lot of air even at 10psi
so you might be on the border line, a dyno plot will give you the answer if you cant find the compressor map info or dont care about the map and reading it
im running a GT3076R with a RB25 turbo's highflowed exhaust side.
84 trim, 0.82 a/r. (i think they the numbers from turbobygarrett.com)
Edited by Pauly33GTS-t
...the correct question is "how much power will stock injectors handle"
jump on some websites of injector makers. they have a calculation applet thing that allows you to put in all your factors and it will rate the injectors for power. rc engineering comes to mind
IF the stock injectors run to 220rwkw as mentioned before, then you can have a t66 turbo on your car, just cap the boost to that power.
get a nismo fuel reg
i would consider changing the pump or hard wire it to 14v (cubes did a howto guide), the wallbro's can be known baddies
what ecu or piggyback are u running? i see no mention of either.
i would suggest stand alone. powerfc is ideal, but pick whatever you like.
either way monitor injector duty and go from there.
stock ecu on those upgrades = bad idea and poor net results
the car will drive like brand new with a complete tune
My local tuner has a few Skylines running around town with 300rwkw with an upgraded fuel pump, rising rate fuel regulator and stock injectors (new turbos and other supporting mods too)... he says when I go to upgrade, I can get 250-260rwkw on a "really safe" tune with a similar setup, but he said the 300 ones aren't running dangerously or anything. This is a tuner that's had several cars feature in HPI (but I don't know how much credibility that magazine gets on here). Because of threads like this, I've been wary, and asked him several times about upgrading the injectors as part of my upgrade plans, and every time he says it isn't needed for my aims (even when I say money isn't a factor in the decision).
paul mate, im running on stock ecu and over the last shit it already seems like a new car...
Im getting hissing and clicking from the injectors tho, me thinks the o-rings have gone on them.
I'll be going Emanage ultimate it seems, as soon as I know for certain someone in adelaide tunes them well.
I would have thought the only real test was an AFR on the dyno?
Any specs on a website will be a guide only.
depending on mods the factory injectors may be fine if they can support a safe AFR at full boost.
Mike
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
