hey guys i got the car tuned today but on the dyno graph the psi is droping from 14psi to 11psi is this normal i got a gizzmo boost controller and the setting is on 56 duty cycle and the gain is 0 would it be my wastegate and also its a highflow gcg turbo
Edited by Jsikalias
https://www.sau.com.au/forums/topic/165742-boost-problem/
What boost controler you using because it sounds like its spiking then going back to stock boost
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069294
From what I've seen of those controllers they are quite shit!! If an EBC has no PI or PID based boost control then you may as well just use a bleed valve. From memory you set the boost from a base duty cycle not an actual desired boost pressure so there is probably no brains behind it anyway.
You could try setting the gain to a higher value but it probably wont work anyway. If it is possible which I dont think it is you could check the duty cycle on the valve to see if its attempting to control the boost. As has allready been said it may be a mechanical restriction.
Edited by rob82
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069512
I had a similar problem and discovered the wastegate arm was hitting the bracket that holds the heat cover because the new dump had a thinner flange.This prevented the wastegate from opening fully and capping boost to 15psi.Anthing over and boost would spike all over the place.However,the duty cycle could be lowered then turn up gain til it spikes then back off a little.
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3070215
its the gizzmo boost controller,
they are known to spike. i have 2 mates that have had em in their cars and the cun*ts spiked like crazy.
my suggection, get rid of the gizzmo and buy and apexi or similar
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072367
yeh the tuner said it could be my wastegate BUT i found the problem, because i have an aftermarket intercooler the new piping didnt give me a nipple for the powersteering vacum so i T pieced it off the boost controller vacum so iv removed the T piece and now it doesnt drop boost it holds 14-15 nice feels faster as well
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072480
go to like super cheap or repco and buy an air compressor fitting. they thread and can easily be drilled and screwed into the cooler pipe. plus add some sealant around it and ur done.
should look like this hen done
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072561
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
