hey guys i got the car tuned today but on the dyno graph the psi is droping from 14psi to 11psi is this normal i got a gizzmo boost controller and the setting is on 56 duty cycle and the gain is 0 would it be my wastegate and also its a highflow gcg turbo
Edited by Jsikalias
https://www.sau.com.au/forums/topic/165742-boost-problem/
What boost controler you using because it sounds like its spiking then going back to stock boost
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069294
From what I've seen of those controllers they are quite shit!! If an EBC has no PI or PID based boost control then you may as well just use a bleed valve. From memory you set the boost from a base duty cycle not an actual desired boost pressure so there is probably no brains behind it anyway.
You could try setting the gain to a higher value but it probably wont work anyway. If it is possible which I dont think it is you could check the duty cycle on the valve to see if its attempting to control the boost. As has allready been said it may be a mechanical restriction.
Edited by rob82
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069512
I had a similar problem and discovered the wastegate arm was hitting the bracket that holds the heat cover because the new dump had a thinner flange.This prevented the wastegate from opening fully and capping boost to 15psi.Anthing over and boost would spike all over the place.However,the duty cycle could be lowered then turn up gain til it spikes then back off a little.
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3070215
its the gizzmo boost controller,
they are known to spike. i have 2 mates that have had em in their cars and the cun*ts spiked like crazy.
my suggection, get rid of the gizzmo and buy and apexi or similar
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072367
yeh the tuner said it could be my wastegate BUT i found the problem, because i have an aftermarket intercooler the new piping didnt give me a nipple for the powersteering vacum so i T pieced it off the boost controller vacum so iv removed the T piece and now it doesnt drop boost it holds 14-15 nice feels faster as well
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072480
go to like super cheap or repco and buy an air compressor fitting. they thread and can easily be drilled and screwed into the cooler pipe. plus add some sealant around it and ur done.
should look like this hen done
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072561
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
