hey guys i got the car tuned today but on the dyno graph the psi is droping from 14psi to 11psi is this normal i got a gizzmo boost controller and the setting is on 56 duty cycle and the gain is 0 would it be my wastegate and also its a highflow gcg turbo
Edited by Jsikalias
https://www.sau.com.au/forums/topic/165742-boost-problem/
What boost controler you using because it sounds like its spiking then going back to stock boost
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069294
From what I've seen of those controllers they are quite shit!! If an EBC has no PI or PID based boost control then you may as well just use a bleed valve. From memory you set the boost from a base duty cycle not an actual desired boost pressure so there is probably no brains behind it anyway.
You could try setting the gain to a higher value but it probably wont work anyway. If it is possible which I dont think it is you could check the duty cycle on the valve to see if its attempting to control the boost. As has allready been said it may be a mechanical restriction.
Edited by rob82
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069512
I had a similar problem and discovered the wastegate arm was hitting the bracket that holds the heat cover because the new dump had a thinner flange.This prevented the wastegate from opening fully and capping boost to 15psi.Anthing over and boost would spike all over the place.However,the duty cycle could be lowered then turn up gain til it spikes then back off a little.
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3070215
its the gizzmo boost controller,
they are known to spike. i have 2 mates that have had em in their cars and the cun*ts spiked like crazy.
my suggection, get rid of the gizzmo and buy and apexi or similar
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072367
yeh the tuner said it could be my wastegate BUT i found the problem, because i have an aftermarket intercooler the new piping didnt give me a nipple for the powersteering vacum so i T pieced it off the boost controller vacum so iv removed the T piece and now it doesnt drop boost it holds 14-15 nice feels faster as well
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072480
go to like super cheap or repco and buy an air compressor fitting. they thread and can easily be drilled and screwed into the cooler pipe. plus add some sealant around it and ur done.
should look like this hen done
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072561
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
