Ive recently bought a R32 off my mate, for now it has all tha performance stuff i want done e.g front mount. But i have another 2k i can spend on the car, what do you guys recommend to do with the money, i was thinking about a bodykit but then i would be driving around with it unpainted then i was thinking of mags, but tires and mags dont think i have enough, so if it was you what would you spend the money on thanks.
https://www.sau.com.au/forums/topic/165788-next-step/
Whats actually been done to the car performance wise? im sure theres some more go fast goodies you could for her :) but if you have everything already i would get the mags first
you don't want to go around with a nice looking car with a hot body kit with ugly wheels :|
https://www.sau.com.au/forums/topic/165788-next-step/#findComment-3070037
It has a exhaust system, massive front mount, turbo timer/contoller. thats it i think, what would you recommend. p.s its running 10psi
https://www.sau.com.au/forums/topic/165788-next-step/#findComment-3070042
well if i was in your situation..
so new car, and 2K to spend
firstly, i would do a full service - oil, oil filter, fuel filter, spark plugs, clean the coils, clean the AFM, clean the AAC valve (do a search for more info on this)
then i would take it to a mechanic and give it a power run on the dyno to check AFRs and check the health of the engine
now, its already got some go-fast bits, so i might check if its a full exhaust or a cat-back, and if its only cat-back then i would finish off the exhaust
now on an r32gtst you can run up to 14psi fairly safely so i would adjust up to 12-14psi and seee how it runs
with the rest of the money i would get the windows tinted, and look for a nice second-hand set of 18" rims with tyres already on them
hope that helps
Warren.
https://www.sau.com.au/forums/topic/165788-next-step/#findComment-3073163
hope that helps
Warren.
Maintainence is the key. You need a healthy motor for the go fast stuff to work. No point in spendin all your hard earned on go fast bits if the car doesnt go. This is what i would do
https://www.sau.com.au/forums/topic/165788-next-step/#findComment-3073788
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
