Was going to get mine done a month ago but thought i would wait for a mate to try it out before i did it incase it killed it...
Hes had it done over a month ago and everything has been running fine... the only thing i was wanting to know (he cant tell em cause he doesnt have DSL or cable) is if you get it done if there were any issues with online updates etc.
Anyone?
Im going to get it done anyway... but just wanted to know.
yeah i've got it done, mate did it. Its pretty simple, just a chip wired to the dvd-rom, even if i unplug it, originals still work etc... don't see it as any risk... but i haven't done any updates yet. But can't see how an update can cause any issues, it's just tricking the drive into thinking a copy is a real game, thats all really.
ok sweet... will get it done then.
its only $50... it dies... put a new one in... my mate said last night the guy who did his has had his running solidly for months.
Theres always someone at their house, always kids and theyre always playing it and they havent had any issues.
  • 4 weeks later...
The modchips more reliable than the system :O
Its only activated for boot up, so its hardly ever getting used.
Nark, its the games that cause the trouble with the Wii, try to only get PAL games.
eg: If u put in an NTSC version of Super Paper Mario in, it updates your machine and turns it into a brick!
Any1 wants theres chipped in Melbourne throw me a PM!!
Nark u have PM!
I was under the impression the disc u may be referring to is a 'setup' disc and is only used once? Or maybe its like oldschool PS2 days where different chips do different things? Whered u get your chip? WES? Devineo?
Got it from ozmodchips
its the Wiikey, i thought you could like run one of the 3 setup disks depending on the region the games from... cause theres PAL, NTSC and JP bootdisks... maybe ur right... i didnt actually read the site properly lol
if you get a LG (or hitachi with the same code) GDR 8164B you can copy them direct to your HDD
http://forums.afterdawn.com/thread_view.cfm/471073 - how to do it.
thats what i use. Bloody drive cost me $60 tho... people are capatilising on the fact u cant get em in stores any more.
Just go to the local markets... they usually have em (like 13 games for $100)... or download em or hire em
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
