So fr0st this sensor as you have outlined above, is it possible to repace the stock narrowband o2 sensor with this and have the stock ecu still reconise its function when on cruise? and also output the accurate a/f ratio to a gauge?
Can it permanently replace the stock o2 sensor without any negative effects?
Its got a simulated narrow band output, you just solder that wire where the output of your stock sensor is.
The only thing I'd be worried about is how last the sensor's last but it should be the same, if not longer than the stock type.
