What Not To Do When Trying To Avoid A Kangaroo
Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents. My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
By Dewayne2121 · Posted
2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor. Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
