Nissan Skyline Gt-r R32 Twin-turbo $21k Price Drop
Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET? Thank you!
Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
