hey, im curious as to what size speakers people have put into their r33's. ive been told that only 6" is all that fits. and by others that 6.5" and 7" fits perfect. ive found some 6.5" splits for the front that i like. but want to know for sure if they'll fit or not first. also what fits in the parcel tray. thanks people!
https://www.sau.com.au/forums/topic/165893-r33-s1-speaker-question/
hey man
i think 6.5" splits will fit in the front. well im guessing they would!!
but in the rear i think you'll have to go with some 6x9's!
but don't take my word for it, could very easily be wrong!! ;)
i got 6" in the front, they fit perfect, cant see why u cant put 6.5" in with little modificatin.
in the back i got 6x9's but i need spacers. i then recarpeted the shelf and make it look like its a moulded parcel. will get pics of shelf if u want but inregards to front shouldn't be a prob.
hey man
6" (6.25 on stock mounts) front - 6.75 rear. with custom mounts anything is possible. 6x9s - no no without a LOT of work.
6.5" will fit if you make an MDF ring to sit them on.
6x9s in parcel shelf are easy. did them last week for -R33GTS- All you need is spacers and they sit perfectly.
So you need a MDF spacer to pull the speaker away a bit, is that so it fits in the hole - or so the back of the speaker doesnt hit the inside of the door?
I'm thinking this is what fhrx did here:
yep.
when i did R33GTS's spacers i made a template so i can just make them when ever i need to without having to measure up again. pretty much the same as Fhrx's. i used 6mm MDF and i had no worries.
for the 6x9 spacers, he already had a set in, but 16mm spacers would work a treat if u were to buy pre made ones.
only things with the ones FHRX show is this. pull your door off, note where the tab is on the back. that is the door pocket seal. with the ones pictured that block is gone and anything in the door pocket goes straight into the door. I usually make an exact copy of them that way you dont loose things.
  • 4 weeks later...
yep.
hi mate can u tell me where i can get some spacers off the internet for my 6x9s to go in my rear shelf r33series1gtst
thx ray
im probably going out to buy a set of 6" to fit in the front + rear on the weekend and will be running off an amp. Anyone know if Alpine do a 6" speaker? Would preferably like to go with Alpine but all i can find is 6.5"
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
