i started to do something similar but was going to use a full ecu. i bought and installed a shift kit valve body but after driving the car for about half an hour i took the shift kit back off because i found it too harsh and rather irritating to drive around normally. my understanding is that it does remove the need to have the auto computer retard the timing on the gear change but i would suggest having a ride in a car with the kit before you jump in.
MMM..alot of people say its just fine with the stage 2 kit???......my question is if its worth doing and then getting a powerfc to tune it with, as some on the forum says this will work for the auto?.........also, is a shift kit faster at changing gears then say a manual??
What exactly did you install?
Also, you seriously spent hours replacing the valvebody, fluid and whatever else and then changed back after half an hours driving? Are you that impatient?
First of all, you learn how to drive it differently after a couple of weeks which removes the majority of the harshness, second of all, I don't believe you. Maybe you should buy a commonwhore with slushbox. It should be nice and smooth for you.
Im seriously considering this option, as it would cost me near $4000 for a manual conversion, which i cant justify at this stage....
Heres what im thinking of getting:
Stage II vavlebody upgrade
oversize auto trans cooler
2800rpm stall converter
maybe a b&m shifter...anyone used these before????
Also, whats the electronic controller that MV auto supplies as well?,
Yeah that's why I rebuilt my auto when I blew it instead of doing the conversion but then I converted later anyway!
Mine was an R34 so already had the steering wheel shift buttons. I'm told that the B&M's are work of engineering art.
Id be doing exactly what you plan if you dont want to do the manual conversion.
Obviously you never gave it time to adjust to way the shift kit works. Im with abobob did you actually instal it cause typically you can't return an entire valve body after its been installed and driven around!
any pics of the B&M shifter in your car(prior to going manual)???.....im really considering the option, and what would the benfit be of going the ratchet shiter anyway if i went along with the valvebody upgrade???
And also, what type of ecu did you run to get into 12's in an auto mate?, i just need some good advice, im nearly sold on keeping auto, and strengthening.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
