Hey all,
Have a whole lot of stuff left over from R33 GTST series 1 wreck
* RB25DET motor with ECU and wiring if I can get it out from car 105,000k's $1200.00
* 5 speed box $1500
* diff centre & shafts $300
* complete brakes & hubs with slotted front discs cables complete $1000.00
* drivers door shell $100
* drivers regulator $100
* passenger regulator $100
* door glass $100
* rear 1/4 glass $50 each
* front reo cut for fmic $150
* rear reo $100
* tail lights $50 ea
* 3 inch cat back exhaust $200
* nismo front pipe $100
* Gab front shocks & lowered springs $300 pr
* 18 inch wheels & tyres, one rim damaged concept 9 black chrome $600.00
* std front struts & springs $100 pr
* rear kyb shock & lowered springs $200pr
* std rear struts & springs $100pr
* front mount intercoolers $100 some minor damage also have pipes some damage $100
* rear windscreen $300
*sreies 1 seats front $50 the pair
*door trim drivers $20 no switches
* series 1 steering wheel $30
* steering wheel surrounds $30
* series 2 wing \black $100
* series 1 wing black $50
* washer bottle $30
* overflow bottle $20
plus more i have forgotten about PM any questions
thanks
https://www.sau.com.au/forums/topic/165971-wrecking-r33-gtst/
so whats the story with the wheels? how bad is the damage? Do you have any pics?
also what brand is the catback?
thanks.
one has a chunk missing from it cant be fixed, they are concept 9. I have attached a pic of them on the car
no brand just put on here in aus for exhaust
Hey all,
* 5 speed box $1500
* door glass $100
* rear reo $100
* washer bottle $30
thanks
need parts can you call me on 0402 513 424 or please give your ph number thanks nick
