Originally posted by nizmokid
no I think theres another Gtir down in HBt same as the one up here in LST, yeah the gtir up here has had a rough life thats for sure.
I herd theres a modded MR2 down there in HBT with a huge Greedy sticker over the door, looked nice but what has it had done to it........... anyone?:D :D :)
Just thought i would answer your question on the MR2. Hes one of my mates, hes had the car for about 5 years and only had about 6 months of actual driving time. all work is done at howell, and the car has just been heaps of problems.
first they had trouble programing the computer, it had to be sent back to melb. then he got it all going and it made 220rwkw. he changed his total setup again and all of the running gear, turbo, intercooler and computer went into a red MR2 with chrome mags.
he got it all going with all of the new stuff, then it started leaking water, howell thought that it was a water pump and when the car finally went in it was a cracked head gasket and the motor was cooked. howell said that he wasnt going to cover any of the repairs but i think they have sorted it out so that hes not going to get charged labour.
when the car is running though, it flys. huge power, hardly any weight in the car!
i hope that answers your question.
  • Replies 67
Originally posted by Mr. En One
Yo Roaldin,
You got that Apexi installed in your GTR yet?
Im running a GTR R33 VSpec and Griffo is just about to install it for me...any joy?
Not yet. I have had some trouble getting decent information about them. The manuals I have are for a Mazda and a Honda. I was hoping the computer would control the boost without having to use a separate boost controller but the FC won't see the map sensor. The business that sold it to me are no help at all.
Good luck with it. Let us know how things go.
Tim.
Guest R33-GTS4
Hey guys, Name is Paul am 17and live in Hobart and at the moment have a 88' Pulsar Vector SSS. Just waiting for a GTS4 to come up for sale in Japan so I can import it :D
I know this isnt the thread but the Pulsar Club and co. is sort of co-organising a big cruise for this saturday. As more details come to hand I will post em up.
Cheers
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
