Been having some problems with pinging once the car is at normal operating temperatute. Plugged the laptop in the other day and saw some crazy timing numbers.. at about 3500rpm it's hitting 40deg BTDC..
So is it possible for an ecu to shit itself and throw in a bunch of extra timing?
Car is pretty stock engine wise, has an exhaust/pod/boost controller and a stock ecu. Didn't ping when I bought the car but after a few months it started to.
https://www.sau.com.au/forums/topic/165987-a-whole-lot-of-extra-timing/
You would be surprised how much timing a car will run especially under part throttle cruise.
The only RELEVANT measurement you can make is your base timing at idle. You measure this with a timing gun and the bottom plug disconnected from the throttle position sensor. It should be 15 degrees BTDC.
Yeah base timing is at 15BTDC. I mentioned 40degrees to my mechanic and he was like that's pretty high.. he said take some base timing out of it which will be pretty gay off boost.
I'm moving through trying to eliminate things, so far done the plugs, fuel filter and changed AFM's. Next on my list is fuel pump and CAS aswell as try another ECU.
Cheers guys, keep the ideas coming :P
Can the timing belt stretch when it get old and result in this sort of pinging? it pings pretty bad if I give it more than say 10% throttle when at normal operating temperature.
Also, a tiny misfire has developed over the last few weeks. Not consistant and not repeatable, just does it randomly and usually at low revs getting on the throttle a bit, doesn't miss under load (happens maybe once a week).
Stretching the timing belt will ordinarily only change cam timing. I doubt it would change it so much as to induce pinging.
What plugs did you use? A dying fuel pump could induce pinging by leaning the mixtures out (not capable of delivering enough fuel).
Not sure what plugs, they're just what my mechanic gave me as listed in some book - it was playing up before the plug change though. Fuel pump is on the cards for next payday :(
So 40BTD isn't anything to be worried about?
as some quick form of insurance.. If I were you I would run out and stick BP Ultimate 98 in it ( if you dont already)
either that or stick some octane booster in there.. that should help reduce the pinging a bit.
Pinging can get pretty serious so dont wait too long before you get it fixed!
also .. does it ping more on really hot days?
Make sure your mechanic goes thru the correct Proceedure for setting the base timing
( some engines you need to disconnect the tps .. rev past 3 grand .. etc etc )
hey bubba your in perth hey? why not take it to a reputable workshop and get em to test it all out ASAP
some motors can survive pinging pretty well .. but not others.
don't want to be up for a rebuild.. give the octane booster a go
Always run it on U98 and I've tried octane booster to no avail :D Doesn't matter what the ambient temperature is, it just has to be at normal operating temperature for a few minutes and it starts to ping. The thing that really gets me is it didn't do it when I first got the car, it wasn't until a few months later that it started to ping. It has also gotten worse lately. It seems like something is/has deteriorated..
As for the timing.. what exactly is the correct procedure? sitting there at idle it reads 15BTDC on the laptop and with the timing light the mark is on 15BTDC.
I'm not really fussed about a rebuild.. it's only an RB20 which wouldn't get a rebuild.. if it blows then it's time to put an RB25 in or my mates RB30DETT :(
If I cruise it it's fine, it's only when it comes on boost with maybe 1/4 throttle that it pings, does it at 13psi and at 10psi (no noticeable difference).
I would rather not take it to one of the big workshops as I have a good mechanic that works for mates rates (when he gets time) and he knows RB engines reasonably well (he built the aforementioned RB30DETT). I'm trying to source a Bosch fuel pump so we'll see how that goes.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
