Here we go again did a search and found out backfiring between gear changes.
Looking at getting my first R33 fresh import.
Took it for a testdrive and warmed up the engine to normal operating temp, and you give it a bootfull and your head learches forward like you hit reverse gear, and than wham ya head gets ripped back into the seat like whiplash almost. Dosnt matter what rev range you do it.
Sometimes it will do a backfire on aceleration and a huge cloud of black smoke comes out of the exhaust (still has jap fuel in it not sure if it is this).
Get this lifted the bonnet and found a hose 3/8 size lying their not connected to anything (around turbo area) could this be the problem??????, hope so as this is a nice car for the price and i got to see and drive before it was complianced and detailed (still had those hard jap tyres on it, pretty much straight of the boat).
Thanks
Edited by Yme33
https://www.sau.com.au/forums/topic/165993-backfire-whiplash/
Umm that hose is probably meant for the wastegate actuator. Sounds like you're hitting Rich & Retard (fuel cut), if that hose is indeed meant for the actuator then the turbo will be spooling uncontrollably, making way too much boost which will cause the ECU to read an overvoltage from the AFM and throw itself into R&R.
If that is the case, my guess is the car had an electronic boost controller which was removed by a complete monkey :P
It sound as if the fuel injector are either pumping too little or too much petrol... I would check the fuel pumps... I had this problem before... changed fuel pumps and it runds fine now... also, remember to use high octane petrol... if you running anything but high octane petrol it will hinder performance heaps...
good luck bro... try this and then tell me how you go...
I dont think he has wound the boost up, I think it's more a case of his wastegate actuator isn't connected to anything (the loose hose he found) and is boosting uncontrollably. I'm not sure where the 33 gets it's pressure signal from.. pretty sure it's different to my 32 which has the pressure nipple on the compressor housing.
That's what I'm trying to say :( Someone needs to tell him where exactly the wastegate actuator hoses go so he can check if that's what the loose hose is.. I have a 32 so I can't tell him as I don't have the dual stage solenoid etc etc.
If its been disconected for a while and it is the hose im talking about it means that whole time its been running unlimited boost. It may have done damage it may not have, it depends on the driving habits of people using the car while its been in this state. Get it checked out before you hand over your hard earned cash.
what is with this term "fresh import". they are second hand cars.... they were just driven in jp and new to aus... what ... people in jp dont thrash thier cars..... so wierd people talk about fresh imports as if they are new cars... particularly car salesmen eh
I know they are second hand but it is tuffer for a frsh import to get complianced than the dodgy road worthy off that guy for a carton of beer
When people use the term "fresh" they generally mean its fresh to australia not that its a brand new car.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
