As far as i know R32/33 GTR are the same and same for the 260rs. I got a R33GTR ECU and it fit perfectly onto 260rs. Atleast thats wat my tuner says
SDU shpuld have more info on this. Aks Simon. He should know
Edited by stasis
https://www.sau.com.au/forums/topic/165998-260rs-ecu-plug/#findComment-3074052
As far as I know R32 & R33 GTR Engine ECU plugs are the same..............not sure about R34. What I want to find out is whether the 260RS ECU plug is the same as R32/R33 GTR or is it R34 GTR? Or are they all the same?
Hi there, just came across this query, lookin for something else as usual but with reference to my most venerable Apexi Auto (Turbo) Timer application guide in english, the following details are listed.
1. Nissan Stagea 260RS Autech version plug type = N4-a
2. Skyline R32 RB20DE throo RB26DETT ('91.8~93.7) plug type = N4-a
3. Skyline R33 RB25DET throo RB26DETT ('95.1~98.4) plug type = N4-a
4. Skyline R34 RB26DETT ('99.1~02.8) plug type = N4-a
5. Skyline R34 RB25DET ('98.5~01.5) plug type = N4-a
Dunno if this helps but there it is. There are other models listed outside these ranges if you have a specific model enquiry.
Cheers GW :(
https://www.sau.com.au/forums/topic/165998-260rs-ecu-plug/#findComment-3080421
one thing I did find (this is not a for a Rb26 though) R33 and C34 will pinout correctly for a PFC but the ECU A/C signal will not be sent out if you do the ECU swap using a PFC for a R33 into a C34. this is part of the reason Ska has a switch on the dash of his. the switch engages the A/C compressor instead of the ECU. everything else pins out and works.
https://www.sau.com.au/forums/topic/165998-260rs-ecu-plug/#findComment-3082158
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
