Hi All,
I've just had new HKS GTSS turbos fitted to my 1989 R32 GTR and when I hold a constant speed at either around 60, 80 or 100 kmph I get air pulsing from the turbos and AFMs (I think). The sound comes from the front left hand side of the engine bay and only comes on with light but steady throttle application. It sounds like an old steam train engine - chushh, chushh, chushh etc.
The current setup is:
HKS GTSS turbos
HKS dumps
Apexi 125mm FMIC
Apexi front pipes
3" Turbo back exhaust
Aftermarket coils
Aftermarket ECU
HKS EVC set at 12psi & 15 psi
Platnium spark plugs
Standard AFMs
Standard injectors
Standard engine
Blitz BOVs
The car made ~235rwkW @ 12psi and 272rwkW @ 15psi (it also made 292rwkW @ 17psi but I asked them to keep it below 280rwkW).
It also stalls when I slow down after getting the revs above 5000rpm. The revs drop below 500rpm and I have to heel-toe to keep the car from stalling. The workshop has adjusted the Blitz BOVs and this seems to have improved the problem but it still happens. Lastly when the workshop fitted the turbos they didn't use the black hose that comes with the GTSS turbo kit. What is that for?
i would say it's mostly tuning. could be the bovs, but then again I've been running twin blitz bovs for nearly 3 years and never had any problems or stalling, or unstable idle etc. so they can be made to work properly.
I've had a similar problem with the GT-SS on my gtr. Turned out that the actuators on each turbo were not opening at the same time causing them to fight against each other. It was only evident when just coming onto boost at lightish throttle.
Put the stock BOVs back on there, it improved as you said when they fiddled with the blitz...
So go back to OEM, its the best item on the market anyhow
The Blitz BOVs were on the car when I bought it. I don't have the standard ones to put back on.
What did you (or the workshop) do to fix the problem?
The rods have to be adjusted so the wastegate opens at the same pressure. It's on off the car job. They should have been setup, or at least checked, before they were put on. That's about the limit of my knowledge.
I'm not saying 100% that this is what's happening on yours. Can you get back to the tuner and get them to see find anything? If it's only just happened after you've had the gtss installed might be something simple. Hose left loose or a leak somewhere.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
