This has got to be one of the funest legal things you can do.
Went to the Circuit Club track day out at Eastern Creek. I've been pumping a few buck into my car (which I bot basically stock) based on a lot of the good info I've found in this forum. So far this has been brakes parts and an external oil cooler. Suspension is on the way. While I want to have that on board for today the timing just didn't work out. Unfortunately, as all you Sydneysdier might note it had been raining night last night.
On arrival, the track was very, very wet. Just what I needed as a first timer - and even slicker surface. I went to sign in only to find out I had been put in the A group (the fastest). I guess they assume a GTR should be there. I suggested they slip me down to the bottom of the field which they did. Glad of that. After the drivers meeting, they had all the car get out on the track and do several slow laps to try to dry things out. Amazing as it might seem, I was able to spin out (at a really slow speed) just after turn 3 and was off into the grass. Great way to start. Several things because obvious at this point:
A) my tires were severly in need to replacement
B) despite my impression of how well balanced a skyline was supposed to be - mine wasn't (probably referring to 1 above)
C) this isn't Playstation
Being the smart and self realistic guy I am - I immediately availed myself of one of the instructors for my first track session. He was great. Break here, accelerate here, point for that apex cone, get your foot off the clutch quicker.....7 laps worth of good advice. He hopped out and then I ran a couple by myself after that.
As the day went on the track got dryer I gain more confidence. Second session I found the speed limited down the front straight (by the 4th I was pissed off it wouldn't let me break 200). I slowly got better around the turns and braked more agressively. By the end of the day I was still a long way from fast but it was becoming really obvious where I was making mistakes and where I could make up time. My tire issues was really more obvious as well as going around most corners I was feeling that I was on the edge of oversteer and the rear came around a few times though I got ahold of it quickly.
A couple of my after the fact thoughts...
If you haven't done it - do it. Don't worry about being fast - just make sure you let faster cars pass.
Its not about horsepower to begin with - it's about staying hooked up. I thought about what everyone has told me on here about being smooth and tried to to that.
If there are instructors - use them. Best decision I made all day because for the rest of the day I knew exactly what to focus on.
Thanks to a lot of people on SAU for good advice and thanks to the guys at Northern Beaches Performance for all the good work they have done on my car. Can't wait to get good tires and the SK suspension bits and give it another go.
https://www.sau.com.au/forums/topic/166017-first-track-day/
good to see you had fun!
It turned out to be a good day :worship:
Andrew - loud Silvia.
Was great. You were sure rocking in the Silvia.
Yes Adam - I can see that coming
Of course now I need new tires given how slippery I was. The good news (cost wise) is it was clear the limiting factor was not the car but the driver.
https://www.sau.com.au/forums/topic/166017-first-track-day/#findComment-3077131
You have a good attitude for the track too by the sounds of it :D
I'm a newbie myself, and of the two track days I have done, I had instructors for both. I've learnt a great deal, and can't wait to get out and do the next day solo.
https://www.sau.com.au/forums/topic/166017-first-track-day/#findComment-3081915
Last time there I was following Oz into that corner at 175km/h. 3 car lengths between us at 175 around a corner is so bloody scary. I was tying invisible rope to his rear bumper just to aid in traction to get around the corner. Still, you make it to the other side alive and the adrenaline rush is massive.
My favourite corner has to be turn 4 though. Has nice camber and it just feels limitless. The only thing that ruins it is having to set up for the next corner so quickly.
https://www.sau.com.au/forums/topic/166017-first-track-day/#findComment-3095845
I love turn 1 :)
With some better tyres, a properly dry track - and maybe I front bar lip I reckon I will be able to hold my car flat out all the way down the straight and through turn 1!
At the moment I back off after the 100m mark, give the brakes a quick test, turn in, let it settle, then plant the right foot :banana:
Reeling faster cars in through turn 1 is a lot of fun!
I love the braking and turn in for turn 4. You get stupid amounts of grip as the road flattens out.
I find the crest afterwards can be used to conveniently point the car at the turn in point for turn 5 too :banana:
Edited by DumHedz
https://www.sau.com.au/forums/topic/166017-first-track-day/#findComment-3096031
I like coming out of turn 3 with a bit of 3rd gear power oversteer :)
my best at EC in my old commo was 2.02 - the skyline was stock and id estimate around 2.07
so at the renew track day - hoping to improve alot!
TJ - glad to hear you had fun, and hopefully see you out there sometime soon yeah?
:banana:
chris
https://www.sau.com.au/forums/topic/166017-first-track-day/#findComment-3096049
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
