Hey guys ,
ive had a problem with my r32 gtr , i had bought it from japan. put it in my driveway and every now and then ill move from place to place oin d driveway to make way for other cars , mind u wen i was moving it i never really warmed it up cause i wasnt really going anywere.... after a week of this id say moving it around wenever i needed too i needed to move it again and it would crank but it wouldnt start .... i ended up finding outthat the spark plugs had been flooded as in too much petrol kicking in while its cold and because i wasnt driving it it flooded...
i was telling a friend about this and he said u will only have that problem if u keep moving the car wen its cold starting and stopping it.... he say once the car is warmed up and u have driven it for a bit u wunt have a problem at all as in if i drove for about 30 minutes.. turned off the car and started it 15 mins later.. he told me it would not floood because the car had been warmed up and the petrol flow went through....
can any1 confirm this ?? or has any ever had a problem like this ???
thanx alot for the hlep guysss :())
https://www.sau.com.au/forums/topic/166049-problems-with-r32-gtr/
Pull the plugs out and check what heat range they are, sounds like its either exteremely rich (what ECU does it have fitted) or the plugs are way to cold for the application. Im guessing its probably got 7's or 8's fitted if the ECU is factory
