Hi guys,
Just wanted to hear your thoughts on this... I used to own a Honda Accord VTEC 3.0 ... it came with a supercharger (not sure which one) but it went... the roar of the V6 VTEC engine would send shivers down anyone's spine... now that I drive a R33 beast... it too has power but if the two would be pinned side-by-side in a quatermile sprint...which would win do you think?
I noticed that with Skylines (Turbos of course)... it has highend power and no so much lowerend and the opposite can be said for VTEC Honda's... is there a way a Skyline can be tuned to have high power in the lower RPM ranges? Is there so controller or piggyback ECU that can adjust this or is this just how a RB is designed?
Thanks in advance...
https://www.sau.com.au/forums/topic/166087-rb-turbo-power-vs-vtec/
  • Replies 98
Thats because you had an 3 litre V6 obviously it would feel more torquey down low than an 2.5 litre RB. More to do with displacement than anything. In this case the supercharger contributes to the low end power too.
In fact most VTEC Hondas are 2l, 1.8l and 1.6l. These are famous for their peaky top end power not torque. so VTECs in general do not have more low end power than your RB.
There are many ways to improve low end power: Increase displacement e.g. RB30 conversion:). Aftermarket cams and etc..
Cheers
Hi guys,
i thoguht the power range in vtecs it higher in the rev range in th elower rev range ti just saves petrol doensn't it? n the revs are longer as well tahts'w ot makes vtecs have the performance they have rite?
but all in all i reckon comes down to the driver :D
...it too has power but if the two would be pinned side-by-side in a quatermile sprint...which would win do you think?
the skyline would win (imo)...if u launched both cars the 33 would be faster....
ofcourse the 33 would seem slower wen u just takin off normally, cause of turbo lag.....superchargers as u prolly know eliminate this lag + a 3ltr is gona help.
u dont have to spend much money on a skyline to get it moving faster...turbo bak exhaust, ecu, boost, fmic, done, and alot fatser than a freggin accord.
EDIT: off the line ull always struggle if u dont launch a skyline...
Edited by 32line
I have raced a Vtec integra 96ish model. He has exhaust and air intake. I had catback on series 1 33... Off the line I got him (comfortably) but top end, Was absolutely neck and neck. I Love the sound of the Vtec when it kicks in.
Although I absolutely adore and love my Skyline to bits... I have to say, if the R33 had a 3.0 litre VTEC-alike engine in it... damn... a new monster would be born... I kinda miss the VTEC yo! LOL
jesus f$cking christ, what a disgrace
Guest
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
