Hi guys,
Just wanted to hear your thoughts on this... I used to own a Honda Accord VTEC 3.0 ... it came with a supercharger (not sure which one) but it went... the roar of the V6 VTEC engine would send shivers down anyone's spine... now that I drive a R33 beast... it too has power but if the two would be pinned side-by-side in a quatermile sprint...which would win do you think?
I noticed that with Skylines (Turbos of course)... it has highend power and no so much lowerend and the opposite can be said for VTEC Honda's... is there a way a Skyline can be tuned to have high power in the lower RPM ranges? Is there so controller or piggyback ECU that can adjust this or is this just how a RB is designed?
Thanks in advance...
https://www.sau.com.au/forums/topic/166087-rb-turbo-power-vs-vtec/
  • Replies 98
Thats because you had an 3 litre V6 obviously it would feel more torquey down low than an 2.5 litre RB. More to do with displacement than anything. In this case the supercharger contributes to the low end power too.
In fact most VTEC Hondas are 2l, 1.8l and 1.6l. These are famous for their peaky top end power not torque. so VTECs in general do not have more low end power than your RB.
There are many ways to improve low end power: Increase displacement e.g. RB30 conversion:). Aftermarket cams and etc..
Cheers
Hi guys,
i thoguht the power range in vtecs it higher in the rev range in th elower rev range ti just saves petrol doensn't it? n the revs are longer as well tahts'w ot makes vtecs have the performance they have rite?
but all in all i reckon comes down to the driver :D
...it too has power but if the two would be pinned side-by-side in a quatermile sprint...which would win do you think?
the skyline would win (imo)...if u launched both cars the 33 would be faster....
ofcourse the 33 would seem slower wen u just takin off normally, cause of turbo lag.....superchargers as u prolly know eliminate this lag + a 3ltr is gona help.
u dont have to spend much money on a skyline to get it moving faster...turbo bak exhaust, ecu, boost, fmic, done, and alot fatser than a freggin accord.
EDIT: off the line ull always struggle if u dont launch a skyline...
Edited by 32line
I have raced a Vtec integra 96ish model. He has exhaust and air intake. I had catback on series 1 33... Off the line I got him (comfortably) but top end, Was absolutely neck and neck. I Love the sound of the Vtec when it kicks in.
Although I absolutely adore and love my Skyline to bits... I have to say, if the R33 had a 3.0 litre VTEC-alike engine in it... damn... a new monster would be born... I kinda miss the VTEC yo! LOL
jesus f$cking christ, what a disgrace
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
