  • Replies 98
"Some sources indicate the 'RB' name stands for 'Race Bred'[1], although this is disputed."
> source: http://en.wikipedia.org/wiki/Nissan_RB_engine
thats good enuf for me :)
RB= race bred.
If thats what you want to beleive (even though they tell you it is disputed), but its wrong.
What does "sr" stand for? and "vq", "ca", "ve", "rd", "vg" and a s**tload of others??
Edited by r32line
they prolly did a survey and found that S and R or GT sells car like hotcakes, although GT stands for Grand touring I think, but it doesn't make sence
Grand Tourinng R?
Grand Touring T?
the same reaason why X, Z sounds cooler than the other alphabets.. Z tuned, S tuned, market anything with these alphabets and they sound so much cooler. Zymol car wax? in comparison to Macquire << sounds like farmer
yeah which Honda has supercharger in It? I think Honda moto sumthing got to do with using N/A beat turbo...sumthing like that, the only turbocharged car they produce are the 20 limited edition NSX, N I think the intension for them to produce the car so they can enter it in JGTC to win~~.
anyone else shaking their head at this shizz...
+1
I drove a Brand new prelude Vspec = and when i got my stock R33 I can confirm. R33 alot faster. those engines got nothing untill vspec kicks in, then when it does, it aint a whole lot of power. Just a nice power curve up top. RB engine is Far more superior for Power and torque. .. Why are we talking about this ?
OK, I love my R33 Skyline... no doubt about that...with some of my mods, it owns... however... has anyone felt what turbo(ed) VTEC engine feels like? I have... very aggressive low range RPM's... the RB engine doesn't have similiar VTEC technoligy although it is a 6 Cyclinder twincam engine... I don't know - do you think the RB is more powerful overall? Please don't flame... just a general question as I honestly do not know...
*bump* ... RB = Race Bread... fact!
thats the thing they're designed to have power at low rpms and at high rpms and a turbo only helps it. its the best of both worlds with the vtec system. the variable valve timing on a vtec is far more superior to an rb
Spot on answer... that's exactly what I think... if only an RB had VVTI or VTEC or something... how crazy would that be... damn.... high and low end power..
From wiki
"RB25DE and DET engines produced from August 1993 also featured NVCS (Nissan Variable Cam System) for the intake cam. This gave the new RB25DE more power and torque at lower rpm than the previous model.
In May 1998 a NEO head was fitted, which enabled the engine to be classified as a low emission vehicle engine (LEV). The non-VCT and non-turbo was fitted to the R32 Skyline, the VCT turbo and non-turbo was fitted to R33 Skylines and Stageas. R34 Skylines also use these engines, but they are fitted with a NEO head."
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
