i had a bit of a pinging problem earlier and decided to run a colder spark plug to bring cylinder temps down.
im currently running 7's gapped at 0.85mm however even after 2-3 days they become fouled. almost impossible to start in the mornings and run like crap for about 5-10minutes.
would this indicate that in fact my car is not suited to running 7's and i should go back to 6's? or is there some adjustment i can make to the spark plug gap? i have a feeling my car just doesnt like the colder heat range plug...
any thoughts?
cheers
adam
https://www.sau.com.au/forums/topic/16611-running-7-heat-range-spark-plugs/
Probably too cold.
I ran my GTS on 8s for a while. When I decided to go back to 6s, I had the engine idling for very short periods (less than a minute), and when I pulled the plugs, they were black with carbon.
You could try opening the gap a bit to ensure a stronger spark.
yeh ive opened them up to 0.9mm...
but they still foul really easily and make driving the car when its cold an absolute nightmare.
is there any advantage in running 7s as opposed to 6s? ie by runnings 7s does it actually make any sort of performance difference?
yeh but it thought itd be worth a try
im gunah put 6s back in tonight i think (unless anyone can suggest otherwise) cos driving the car atm is rediculous
im running injector cleaner through this tank of fuel and see what that does. theres a fair bit of work involved with getting the injectors out so im not gunah rush into the flow-testing idea
adam,
If you don't have enough timing advance and don't run highish boost or revs then colder plugs will foul.
7's aren't all that cold, and with RB's the factory ecu like to run 14 AFR's at idle and low throttle so they should stay sort of clean.
My 7's are only a little fouled at the moment thanks to me driving around with a blown ic hose, other than that they are fine.
Im thinking of running 7's aswell, considering i've powered up my SR20DET by ~60% over stock. Surely I should go one colder? Cos i read everywhere that ever 75-100hp increase u go 1 range colder. I might just go buy 1 colder copper plug (Heat/R 7) see how it goes. So if it fouls up, at least the car will hopefully still be fine.. Maybe thats an idea for everyone! =)
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
