G'day guys,
Im looking to sell/trade my '98 model R34 Skyline GT-T due to looking to purchase a house.
The car was imported from Japan by Toy Shop Imports in NSW, it was their compliance vehicle to get their licence so everything was done prior to me purchasing the car (belts changed, fluids, water pump, etc.). The car still has 2 years aftermarket warranty of the highest grade (so every nut and bolt is covered under warranty).
The car is higher than average in kms, but I found a lot of imports that say 40,000kms aren't really anywhere near that in quality this car is.
Some of the features of the car:
-19" Gold Lenso Muse
-Custom made 3" turbo back exhaust
-Power FC (Tuned at Boostworx - over 200rkw on a safe setting)
-Blitz SCiD III - Dual Solenoid Boost Controller
-Blitz Auto-Turbo Timer
-JVC Headunit with Pioneer Kevlar Comp. Speakers
-Genuine Nissan floormats
-K&N Air intake filter
-And all the usual R34 goodies
The car is serviced every 5,000kms with Motul 10w40 and K&N oil filters. Kept in overall good condition externally and internally. Never really driven that hard, mainly my daily commuter (I do about 400+ kms a week).
Now for the trades, Im looking for something preferrably Japanese that either goes sideways (Silvia, 180, Ceffy) or something that goes fast (R31 coupe, R32 GT-T/R, GTiR, XR6 turbo) + cash adjustment.
I bought the car a year ago for 28k and spent a bit of dosh on it, so I would like to see offers around the price.. If I'm being unreasonable by all means let me know.
Pictures without Lenso's on it, R34 standard rims wont be included with the purchase you'll get the 19" Lenso Muse ones.
Edited by Scrub
https://www.sau.com.au/forums/topic/166130-wtst-r34-skyline-gt-t-south-aust/
Sorry guys, I've been very busy. The car is a bit over 100k in kms, and I will get some pictures up as soon as it stops raining (Gee, I didnt think I'd be saying that soon).
If anyone wants to have a look, I live south of the city and work in the north. Viewable at both locations call: 041 393 1027
  • 4 weeks later...
  • 3 weeks later...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
