For Sale R32 Gtst 11k!
ok guys i have to sell the object of my affection for the last 3 years.
its a 32 gtst with 176,000
The car is in good condition the whole time ive had it its been
serviced routinely because i work for an oil company and
dont have to pay for the stuff.
Also the car is fully Engineered so no police issues to be had.
it has
gcg high flow rb25 turbo
full 3 inch exhaust
front mount intercooler
remapped computer
gtr fuel pump
electronic boost controller.
hks boost gauge
turbo timer
window lifters
short shift kit
car also comes with the stock spoiler and spare set of s14 200sx
stock rims that could use rubber if u want them.
i installed the turbo about 10k ago, and it has seen 12psi
on the odd occasion since then.
the car is making 170rwkw atm, i cant find the dyno sheet
but yeah thats not a very bold claim anyway.
afm and injectors and another tune should see 200rwkw
im asking $11,000 neg
my name is Declan
phone 0404143865
and pictures are here
http://declan83.customer.netspace.net.au/car/
Edited by ODessA
  • 3 weeks later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
