Hi guys I recently purchased a oil cooler kit from xxxxx, wanting a 19 row cooler for my R33.
It finally arrives and it's a 10 row cooler. How much worse is this going to be for my car? Can I still use it? It'd take ages to send back to Japan and recieve a new one that is 19 row. The car is a series 1 GTS-T running a garret 3071R and all supporting mods. Any insights on this problem would be great thanks guys.
Cheers Steve
Edited by Zilch*
https://www.sau.com.au/forums/topic/166157-oil-cooler-question/
Cheers Steve
It depends on your car, your engine setup, how often you punish/trackday your car etc.
I use a Trust 10 row kit on my GTR producing 500awhp and its fine.
Steve,
Any price difference or is it the same?
How much all together delivered?
I need one!
But I'll be using standard turbo - I just dont want to punish the car too much at the track
Blitz, thanks mate for the info, that's what I needed to know, I've actually gone and decided to get just the oil cooler core from justjap in 19 row for $100 and just cut my losses on the other one, so if you want a spare... :)
Chris, pm me and I'll tell you who NOT to buy it from incase it happens to you as well, ordering the right one and receiving something smaller LOL. To answer your question a oil cooler and filter relocation kit cost me $380 delivered.
Unless you are doing the work yourself the pricy part of an oil cooler is getting it installed. I'm running a 19 row from Just Jap and it cost a fair bit to get it put in. Awesome job and I'll post up pics in the DIY thread.
I'm running a stock (GTR) oil pump and had it out on the track for the first time Wed. It oil temp was barely over street driving levels.
Blitz, thanks mate for the info, that's what I needed to know, I've actually gone and decided to get just the oil cooler core from justjap in 19 row for $100 and just cut my losses on the other one, so if you want a spare... :thumbsup:
if the cooler you have now is the trust one, i personally would not be swapping it for a just jap one. either just use your 10row one, or ask for the 19row to be sent and send the 10row back.
The cooler I have now is not a Trust one as far as I know, it's a universal one from a well known trader on here(not slide)
We are doing the installation ourselves and so I'm not worried about costs in that regard, so yeah I might just buy a universal 19 row core. Thanks for all the info and suggestions guys.
Hi Steve,
Id like to apologise for the mix-up with your order and any inconvenience caused.
We accidently sent you the 11 row cooler by mistake and I have aranged for a 19 row cooler to be sent to you.
You should have it within the next few days.
I have sent you a PM with further details.
Regards,
Paul.
  • 4 months later...
Hey guys.. sorry for veering the discussion a bit off topic but i was after a bit of help. the picture above shows what i have sitting in the garage ready to go into a r32 gts-t running a 2871r w/ upgraded fuel pump and necessary mods..
I was under the impression that when relocating your oil filter you needed a sandwich place as well as a relocation plate (which your oil filter will eventually plug into). I have been provided with the sandwich plate.. now is this just a spacer which allows for sender units and braided hoses (pictured above) to be installed? essentially keeping the oil filter in the same location (give or take 15mm)..? or am i missing a chunk of metal?
sorry if the question sounds stupid but I am a noobie..
cheers, tushar
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
