Biagio are Brazilian made turbochargers based on Schwarzer cartridge assembly design and Turbonetics/Garrett wheels.
Most compressor wheels used in Biagio turbochargers are Air Research Garrett wheels.
For more information on them visit the main website.
http://www.biagioturbos.com.br/
You can even see how they are constructed :)
http://www.biagioturbos.com/ing/process2.asp
They are not cheap Chinese/Asian copy turbochargers.
The balancers used for these turbochargers are Heinz which are the same balancers we use for our turbochargers that we make.
https://www.sau.com.au/forums/topic/166170-biagio-turbo/#findComment-3077919
Slide, Have you got any dyno sheets or results for any of the turbo's from clients?
I was going to PM you again about results for a T40 and T45 on an RB30DET but since there's a thread I'm sure everyone else would be interested in the results as well. Even a full boost RPM and peak power figure would do me fine.
Thanks
https://www.sau.com.au/forums/topic/166170-biagio-turbo/#findComment-3079017
  • 1 month later...
  • 3 months later...
  • 2 months later...
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
