Biagio are Brazilian made turbochargers based on Schwarzer cartridge assembly design and Turbonetics/Garrett wheels.
Most compressor wheels used in Biagio turbochargers are Air Research Garrett wheels.
For more information on them visit the main website.
http://www.biagioturbos.com.br/
You can even see how they are constructed :)
http://www.biagioturbos.com/ing/process2.asp
They are not cheap Chinese/Asian copy turbochargers.
The balancers used for these turbochargers are Heinz which are the same balancers we use for our turbochargers that we make.
https://www.sau.com.au/forums/topic/166170-biagio-turbo/#findComment-3077919
Slide, Have you got any dyno sheets or results for any of the turbo's from clients?
I was going to PM you again about results for a T40 and T45 on an RB30DET but since there's a thread I'm sure everyone else would be interested in the results as well. Even a full boost RPM and peak power figure would do me fine.
Thanks
https://www.sau.com.au/forums/topic/166170-biagio-turbo/#findComment-3079017
  • 1 month later...
  • 3 months later...
  • 2 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
