ok guys its my moment of truth! REGENCY tomorrow morning!! everything i know of is out and ready so fingers crossed!! theres a few questions i need to answer.. 1- how long is an average inspection? 2- do they check under the dash? 3- wats the deal with exhaust smoke (as mine is blowing a little black due to no tune and sitting around for 6months)? 4- and i dunno about the db of my exhaust....
anyways this is my first trip any tips???
cheers guys if she comes good i will cruise with u guys soon and introduce myself!!!
Edited by rad33
https://www.sau.com.au/forums/topic/166195-defect-cleared/
yes they probably will check everywhere and anywhere, including pilling off the ecu kick plate to see if its aftermarket.
Dont expect to come through first time and u will be ok. U will be suprised what they are most likely to pick on. Inspection tends to take as long as they feel like being picky.
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3077390
sounds hard
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3077616
They generally don't check for aftermarket ecu's unless its been defected for it or something doesn't look right. i.e different injectors, afm etc.
Regarding turbo timers etc.. Just make sure its disabled and if possible shove it right up behind the dash where it can't be seen or felt. Good luck getting it back out though as there's next to no room up behind the dash's of these cars. :thumbsup:
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3078341
ok heres the verdict.....
FAILED lol..
as i expected, but all wasnt bad!! the inspector was a champ! we like talked about new mods and upgrades and wats a good turbo and stuff! he also showed me and gave me tips on getting it back on the road!
ne ways heres the list
-eye level rear brake light
-fuel regulator to be removed (didnt know i had one lol)
-boost controller solenoid to be removed
-rear centre seat belt to be fitted as compliance plate says 5 seater
-oil leak NEAR turbo to be cleaned
-both rack boots broken to be replaced
-RH rear steer inner rack end has play
-fix play at left front wheel bearing
-fix play at left front upper arm
-rh front upper arm bushes have play
-side indicator globes worn, need to be amber
now all i need is help on parts to fix, were i can get them, whos best to do it and $$$$$
oh he didnt even check to sound on my exhaust and he passed my gtr cooler!!
and he never saw my timer!!
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3079998
sounds like a front left wheel bearing, a couple of bushes and a lil bit of other stuff to do
for the rack boots etc try
Driveshaft & CV Centre
12 Deloraine Rd Edwardstown 5039
(08) 8374 2944
if ya south(ish), i can put ya onto a mobile mechanic who mite be able to do some of that work for ya
otherwise i reccomend
Rod Webb Auto Electrical
2 Muriel Ave Somerton Park 5044
(08) 8294 4599
and of course, Boostworx
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3080094
FAILED lol..
just make sure you fix those problems for the next inspection and you're bound to pass. Seems like the majority of the problems listed you can do yourself, if you're willing haha.
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3080575
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
