Hey all...
Im here on Behalf of Nizpro to let everyone here know about there NATIONAL DYNO DAY
Nizpro Turbocharging in association with Nizpro Dealers and Suppliers are holding this years first National Dyno Day.
How this works:
We will be holding 3 dyno days throughout the year. The first one being on Saturday June 16th. The dyno day will be held at Nizpro Turbocharging (Bayswater, vic) and also on the same day in NSW, WA, QLD & SA.
If you will be attending the dyno day at Nizpro (Bayswater, Vic), please read the details below, and add your name to the list in this thread.
If you will be attending the dyno day in your state, contact the appropriate Dealer/Supplier below.
Date: Saturday June 16th
Price: $45 for 3 runs, Includes a Printout.
Details: This dyno day is open to any vehicle make/model!
There is no horsepower limit, and Blowers etc are all welcome to be used.
There will be trophies awarded on the day.
Classes:
4 Cylinder Naturally Aspirated
4 Cylinder Forced Induction
6 Cylinder Naturally Aspirated
6 Cylinder Forced Induction
8 Cylinder Naturally Aspirated
8 Cylinder Forced Induction
There will be a BBQ and refreshments served on the day. We will also be showcasing some Nizpro kitted cars on the day.
What do you need to provide?
1. Ensure you have at least 1/2 tank of fuel, there is nothing worse than running low on fuel on a full power run.
2. All vehicles must have exhaust systems complete from front to back.
3. If you have any special requirments in relation to the way to vehicle will be run, please let us know in advance.
4. The dyno day is held for rear wheel drive cars only, with the exception of 4WD's ONLY if they you take out your front drive shaft before arriving.
Legal Terms:
Prior to placing the vehicle on the dyno, you will be giving a form to sign authorising your vehicle to be placed on the dyno.
1. You must state on that the max RPM range to take your vehicle to.
2. By placing the vehicle on the dyno, and signing this form, Nizpro does not accept any responsibility whatsoever, in any way, manner or form in relation to any Engine/Fitment damage that may occur to the vehicle or yourselves.
3. Before your run, it is expected that the vehicle is warmed up and ready to go on the dyno.
4. Remember to check that your vehicles oil and water levels are correct.
What do I do now?
Put your name in this thread if you will be attending the day (June 16th), at Nizpro Turbocharging (Bayswater, Victoria)
Remember, if you are not in Victoria and want to attend the day at another location, contact the below Dealers/Suppliers for their information!
OTHER LOCATIONS FOR DYNO DAY 16TH JUNE
NSW:
TuneHouse
11 Chandler Street
Marrickville, NSW
PH: (02) 9557 4000
WA:
Xtreme Ford Tuning
16 Runyon Rd
Midvale. WA. 6056
PH: (04) 3340 5278
QLD:
Elite Automotive
166 Beatty Road
Archerfield, QLD 4108
PH: (07) 3274 2445
SA:
KPM Motorsports
257 Goodwood Rd
Kings Park, SA
PH: (08) 8299 9998
Come one come all!
https://www.sau.com.au/forums/topic/166201-national-nizpro-dyno-day/
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
