FS: Cooler
Fancy it getting to the point where Ozzies would consider importing f**king Datsuns from the US?
So the issue only occurs when indicating right, AND you're missing a bulb in it. Normally on old flasher relays, when a bulb blows, they start to flash quicker. If you have potentially another short, or a couple of lower resistance bulbs, the constant noise you might be hearing is actually the flasher relay dropping in and out really quickly. I suspect if you get your front indicator wired in, your symptoms will change...
Good evening SAU team , just a quick update on the 400r , just had the guys Lush Auto Spa (https://lushautospa.com.au/) do full paint correction and ceramic coating(Exterior and Interior) pictures look great , I'll be picking it up tomorrow. Highly recommend these guys if you are looking at brining back the since back to your vehicle.
