Hi Guys,
I know its my forst post but i need some help.
I am hearing bit of a knocking noise coming from the top of my R33 GTR engine (turbo side) a few seconds after it starts. The noise kinda increases with revs but disappears after 3k rpm but returns when i let go of the gas. The knocking does go when oil get slightly warm after 3 or 4 minutes. I have also taken the oil cap off when the engine is on and i can hear a clicking/tapping kind of noise. The noise has got a bit louder over time but i am hoping its the clearances or lifters and nothing more than that.
Anyone have any suggestion or further dignostic help???
Gerry
Edited by Dr GTR
https://www.sau.com.au/forums/topic/166248-knocking-from-gtr-engine/
Hi Guys,
Gerry
are u sure the noise is comming from the top of the engine? not the middle or bottum?
I thought when my gtr was knocking it was coming from the top but it was actually bottum end bearing
Bent valve(s)!!
This happened to a customers GTR, previous owners tried to chase power with boost, leaned out which caused melting of plugs and broken ring-lands. The melting of the plugs caused material to get caught under both exhaust valves at no.6, something else could have gone through engine also?
If the valves dont seat then they have too much clearance and knock at top of engine.
G'luk
Thanks for your response guys....The bearings were only done about 3 months ago due to a dodgy filter so i am hoping that they havent gone again. When they did go the noise was not like this and the mechanic seems to think that the noise is my clearances thet need sorting. This time its kind of coming from the top and definately towards the middle of the exahust side cam but as i said the noise does go away after a few minutes.
Gerry
Edited by Dr GTR
whats the oil presure like? hot/cold? ive never ever heard a big end knock disapear with heat. maybe a dodgy lifter
The oil pressure is great due to the trust oil pump. Im seeing 7bar when the car is stone cold and just over 2 bar on idle when the oil reaches 80 degrees. Pressure whilst driving is also very good. I also have trust sump extension.
Gerry
Here is a sound clip io managed to get today when i started her.
Full spec of the car is as follows just in case it could be one of the mods
Apex V-max SPL pistons with cooling channles
Trust rods
R34 crank balanced
Nismo 24 U Block
Apexi 280degree cams with 10.5mm lift
Apexi double springs
Trust greddy Intake plenum
Greddy t517z trubos
Trust oil pump
As i mentioned, this noise does go after the oil starts warming up and there is no loss in performance thats for sure lol
CIMG0895.WAV
Edited by Dr GTR
Geez man - I wouldn't be running the engine - take it to a workshop !
Fingers crossed its nothing major man........My tuner is coming over in the morning to have a listen to it. If it was the bearings wouldnt the noise be permanent???
Gez
Edited by Dr GTR
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
