Hey guys,
Just done bottum end on my stock 33 GTR, probably bearings. While im down there im going to put some pistons, rods n n1 oil pump in aswell. Im thinking about a new crank too if needed? ill be sending the block away aswell if i decide to keep the rb26 bottum end. After thinking of replacing all the internals it might be better for me to go rb30 bottum end if im going to be buying everything new anyway?
I currently have standard turbos running @ 1bar. I can source a gt42 1000hp turbo pretty cheep. what else would i need to upgrade even if i run the gt42 on low boost for now untill i can afford to upgrade the head and fuel system?
:EDIT: another question is, to get my car back up n running asap can i have a fully rebuilt bottum end and the rest of the engine stock? is there a problem in doing that?
Also would my power fc work with an rb30 bottum end?
Edited by RICK-GTR
https://www.sau.com.au/forums/topic/166262-gtr-rebuild-undecided-need-input/
my advice is if you are going to get a new crank anyway, just buy an HKS or tomei 2.8 litre kit. it comes with rods, pistons, rings and crank. and will be suitable for your massive power goal. also, i would forget the plan of running a massive turbo at low boost. it will be a dog. far better to get something in the 500-700hp range. don't skimp on your turbo. it has one of the biggest effects on how your car drives and performs.
not really. around $5K for a kit including a 2.8 crank, good rods, good pistons, good rings.
now price up:
set of pistons
set of rods
set of rings
new R33 crank.
I would say that will touch $5K easily if you are buying good parts, and you now still have a 2.6...
Pistons + Rings - Arias or Cp or Tomei, up to $1500
Rods - around $1000
Crank - Around $1000
Total = 3.5k
If you go rb30 bottum end add the cost of the block and pulleys n adaptor plates i think (unsure, there is a topic somewhere) couldnt equal more than $1400 so youd probably just get it done for under 5k for rb30 complete bottum end
Prices on HKS 2.8 litre kits start from 5k for 600ps
21004-AN002AU $ 5,313.67AU HKS RB26DETT 2.8L STEP 1 441kW(600ps)
21004-AN004AU $ 6,955.01AU HKS RB26DETT 2.8L STEP 2 588kW(800ps)
2104-RN006AU $ 8,696.49AU HKS RB26DETT 2.8L STEP 3 882kW(1200ps)
you might need to check that crank price. I have a feeling the nissan crank is a fair whack more than $1K.
but yeah the rest is about right. not sure where you got the 2.8 litre prices but last time i checked them they were much less than that.
but it's up to you. RB30 is a good option. lots of power and torque. having been in both I prefer the 2.8 though.
fair enough. sorry my bad.
but it doesn't change my opinion. you are getting a lot more value for $$ I think with the 2.8 litre vs rebuilding with a new stock crank. the best cars I've been in were japanese 2.8 litre strokers.
New cranks are difficult to find at the moment, factor that into your considerations as well >_<
Im with Beer Baron on this one, if you are planning to switch to a big single, the cost comparison between rebuilding your 2.6 with forged components and purchasing one of the available Japanese 2.8 kits be it an HKS or Tomei version, make the stroker kit a much more attractive option.
Ill be happy with 400 - 500 awkw
Rb30 block i can get for $50 too, then the cost of sending it away to get cleaned up, Im sure vl turbo internals would be cheaper than 26 internals?
Still undecided n still learning
i dont think its that easy is it?
from memory its only certian rb30's that can be used? someone can correct me on this maybe?
for all your rb30 conversion have a good read of this.
http://www.gtr.co.uk/forum/upload/52458-rb...-lots-pics.html
it provides alot of info from a home built rb30 in a 32 gtr
Yer i read that there is alot of little things to do and i know a place where i can get adaptor plates n stuff made for the sump etc. Unsure if rb30 would work with my power fc
you need to do a lot more research. why wouldn't it work with a power FC? how does the power FC know what size stroke your crank has? or what size bore you have? the head is still the same. the sensors are all still the same. remember the ecu just controls fuel, and spark (well obviously a few other little things too). it doesn't care about RB30, or RB31 or RB27 or RB28 etc.
i have to be honest. it seems like you have made your mind up. by all means go with the RB30, or the stock 26 build. but like I said if you are buying all new engine parts anyway the 2.8 kits are a good option and nearly all the top street and time attack cars in japan are now running 2.8...
Your using the RB26 head, so the PFC will definately work.
Whats your budget? and is it 400 or 500rwkw? There is a fair difference between the two
aim for 450awkw that doesnt have to be right now either, i just want a bottum end at the moment to handle 450awkw and later on i will do headwork n turbo, i already have a fuel system lined up for later on also. There is no real budget but id rather do it all in stages than throwing 15k down in one week haha
Edited by RICK-GTR
well that's a start. a reliable 450kw costs around $20-$25K.
whatever way i decide ill be making a document for other skylines australia members with price's. I have a friend who is very good with engines n fabrication work wich we are doing everything ourselves so it will not cost me as much but i want to have some information about this kind of decission for other people.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
