the other day while driving my car the electrics started dimming including my dash lights etc, head unit turning on and off, power steering gone. finally got to friends house and the car just died. left it for a few hours then it started up again but only to have those doddgy electrical problems again and then when i came to a stop the engine just splutters out and dies (if i dont keep foot on accelerator it will die, but even then i couldnt keep it on for long when i had tried pumping the gas). had to jump the car to get it back to friend house, it starts up fine but will only keep running for a little once the leads are removed, then will konk out again. im totally stumpd on this one help would be much appreciated!!
just a crazy shot in the dark but... get a new battery...
yea, my batt is only 1 yr old.. i thought of that too but why would a dead battery make my engine konk out even after it has been jumped and started running for awhile. like i can get it started no worries with a jumper but then driving for a little while it will die. ive found taht when i use anything related to electrics the rpm drops off and dies. for example pressing the break will cause my engine to die, indicators will cause my rpm to drop off etc. i have no idea with this
ive just limped it home from my friends place where it was, i had to pull over twice and jump it on both occasions cause it just wasnt holding rpm. but then all of a sudden on the home straight it seems everything seems fine eg power steering comes back and on all my electrics come on fine so its sorta fixed itself. however im afraid its just a matter of time b4 it happens again so i need to find out what it is. could it have anything to do with earthing wires or fuses or any of that? i have no clue
Check cabling from the battery and possibly the alternator?? Could be a loose earth somewhere or a failing alternator.. either way if your battery keeps getting drained it will be stuffed and need replacing.
If its something you can't find easily take it to a auto elec or mechanic as you really don't want to start messing with the electronics/wiring if you don't know what you are doing... >_<
man come on... get a new battery...
if your jumping it, then your obviously using the other batteries power, not yours... your battery is f**ked, the cells in it are dead, they can no longer hold a decent charge...
that or the alternator isnt charging it... try a new battery first cause its cheaper...
if theres a loose wire on the laternator somewhere, and your battery is f**ked, as a malfunction alternator will do, then that would explain what just happened... you can run your car on next to nothing if the alternator is running... so if it came back while you were driving, it would have supplied power to everything... i would get it checked out by a friend in the know... it may just be a shit earth wire, where a shop you dont know will charge you $180 bucks or some shit to replace... when a mate will do it for a beer :P
if theres a loose wire on the laternator somewhere, and your battery is f**ked, as a malfunction alternator will do, then that would explain what just happened... you can run your car on next to nothing if the alternator is running... so if it came back while you were driving, it would have supplied power to everything... i would get it checked out by a friend in the know... it may just be a shit earth wire, where a shop you dont know will charge you $180 bucks or some shit to replace... when a mate will do it for a beer :D
Just took a look at the car properly today and came to the conclusion that it was the battery like you said. Since its a RACV garunteed batt i call down a racv person and he tells me its actually the alternator which isnt charging whatsoever.
Looks like a few hundred out of the pocket to fix this...
Edited by lteh
Sounds like alternator not charging your battery.
you dont get points for it if you say what it was after the guy said it... :P
And i would probably check the voltage on your battery too... they weren't designed to take that kind of punishment... you may very well need a new one... i would recommend Delkor... lovely batteries :P
anyway, good luck with it mate :(
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
