  • Replies 90
had a look at the website. just gotta say that those pics are awe-inspiring to say the least. can see alot of love goin into the car. that amount of dynamatmust have cost u an arm and a leg. worth goin to autosalon just to see ur car. :)
Thanks Gabbo, yeah it did cost a bit in the end, but it's worth it just to hear the door go thud when you close it now rather twang. Windows are in now and I just spent the arvo putting the interior back in. Good to see it all coming together.
If anyone was interested in buying the Recaro's I had planned for Sillbeer, drop me a PM and I'll put you in contact with the now owner of the seats:
- Black Suede w/red stitching
- Recliners
- Mint Condition
Recaro SR-II
Cheers
Brendan
Edited by VSPEC32
Which seats? The recaro's...I have a FS ad up for them in the WA for sale section. Check em out there.
http://www.skylinesaustralia.com/forums/in...howtopic=175427
Edited by VSPEC32
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
