Morning All
I'm thinking the pump may be gone/going in my r32. The power steering works fine for the first few minutes of driving then it all of a sudden switches off and its like steering my old datsun. Any ideas??? should i just change the pump?
https://www.sau.com.au/forums/topic/166316-power-steering/
is your speedo working?
if so check the solenoid wiring to the power steering rack to ensure the rack is still recieving the power signal from the ecu that controls its assistance
Yeah speedo is still working. i'll check it out over the wknd. thanks. Has this happened to anyone else? i havent really heard of it being a common problem.
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3080494
hey thats liek me! lol i was asking this question a while back but no one answered :)
ill keep an eye on this thread.
its liek all of a sudden turns off, but mine is at random times... so i would usually stop and then flick the switch to rwd, then back to 4wd. usually fixes it
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3080581
check fluids in both power steering and hicas. watch speedo CAREFULLY and see if it is bouncing. even just a little bit. sign of worn speedo cable. this does affect steering. check hicas computer bolted to the bottom of the parcel shelf in the boot. theres a light on it that will blink if theres any errors. error codes are in the service manual
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3082011
There's a light on the HICAS module? where abouts.. There's one on the attessa module, but even the workshop manual only shows to check the dash light once in diagnostic mode for hicas, not any mention of an led indicator..
James.
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3082072
I checked the fluids a few months ago when it first started happening. I actually had the speedo re-calibrated about 8-10months ago when it was reading ridiculously random speeds. i have noticed that it is bouncing slightly though. The Hicas light usually comes on after the power steering has stopped. they run off the same pump, but they stop at different times??? or would there just be a delay for the hicas stuffing up?
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3083241
  • 4 weeks later...
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
