SAFC: SAFC II
GearBox: AT
Turbo: r33 hi-flow front/vg30 rear
Exhauset: 3inch splitdump, wrapped.
Air Filter: open pod
Injectors: Factory
Intercooler: Copy Hybrid
Fuel Reg: Stock
Fuel Pump: Stock
Boost Controller: rb20 act. running 10-12psi
BOV: plumb back
234.9rwkw@10-12psi
  • Replies 43
Posted Images
Just for the guys asking about the Fuel Pump
If you want around the 200rwkw then you need a new pump, the stock will reach its limit about 170 - 180rwkw.
then you can wid the boost up a little more aswell cause fuel supply won't be an issue.
I think thats what happened to me, cause i had my boost set at 12psi but it was knocking so they had to drop it to 9-10. Do you think by getting a new fuel pump, putting the boost back up to 12 and getting it dyno'd again will get me to 200?
stab in the dark but it could be your spark plug gaps for 10psi plus boost they should be gapped at 0.7 - 0.8mm gap
Yeah i guess if you got that power on stock fuel pump then itshouldnt matter, but mine could be stuffed. Wouldnt hurt changing it anyway its not that expensive compared to buying a new ecu.
r33madd i gapped my spark plugs to .8 when i changed them after i got the car. Would changing them to .7 help?
my car made 200.2kw without an safc and my afr at 10.5:1 top end, on 12psi dropping back to around 10psi top end also. What do you guys think I could gain with a safc??? and say tuned at around 12:1 afr??
I have a 96 r33 s2 with 3" turbo back zorst, fmic 600*300*76mm, high flow fuel pump and stock turbo with steel front wheel? ( series 2 should have plastic one.)
Cheers
Russ
Roughly what kind of time is required on the dyno to get one of these doovas working properly. I have read about 1.5 to 2 hours yeah?
yea mine took 1.5 hours but it can also depend on your car and the tuner
so do you reckon that i should be investing in a upgraded fuel pump before i get a dyno tune with my safc?
will there be much of a gain if any?
running 12psi boost, hks pod, fmic, full exhaust including dump and afc neo?
should i go for a pump and wat power should i be expecting?? around 180 hey?
anything else that i could upgrade easily to get me more power?
HI,
Guys if your fuel pump is causing you issues, some may be faulty change it. If not leave it.
What I am saying is save your money(or if you can afford it buy it). On the other hand I didnt have money to throw around and went to the dyno with a 'it will make as much power as it wants to attitude'..
stock fuel pump I made 234.5rwkw..and so many others also...this proves that the stock pump is capable? Unless there were different model gtst r33 pumps, which I doubt.
I dont want to mislead anybody, just trying to shed some light..
Fuel is important in the long run, as if there isnt any well you engine will cease to work.
Cheers
my2c
well its obvious a fuel pump and reg increases power but that auto Steg with 160 at the wheels is pretty impressive
plenty of auto stageas in australia with >200 awkw. Same upgrade potential as skylines but you lose an extra 10-20kw through the drivetrain due to the extra weight. They're about 250-300kg heavier than a skyline :P AWD helps to overcome the weight a little bit - especially when you increase the kw.
You can gain an extra ~20kw by removing the front drive shaft, making it RWD, but the reality is that people have done this and found that the car is actually faster in AWD (almost a 1sec difference in 1/4 mile times). Factory RWD-only stageas are a LOT lighter (front diff and ATTESA setup adds about ~200kg!!) however so these would have performance very similar to an equivalent RWD skyline. :(
yeh i am going to go on the dyno and get my afc neo tuned and see how the stock fuel pump handles it, hopefully everything goes all good, if not well i will have to upgrade it.
i will have, afc neo, fill 3" exhaust with dump pipe, air pod, fmic, bc runs 12psi.
what kind of figures do you think i will be expecting? hopeing for 180 or something higher or there abouts.
should be up on the dyno within the next month or so
Paulr33...
time will only tell if it is a timb bomb tune..Can you explain to me why it is a timb bomb?
I know many people change the pumps because of the info they get on these type of topics and some times they would probaly definately not need it. It has been a few weeks of testing the car and it is holding up fine for now. It seems to be suppyling fuel fantasticly as the AFR's when dynoed were fine?
Can someone please post up if they have had there stock pump run of efficency at higher power levels. All the time I hear people claiming that there faulty not that they cannot supply the fuel at certain power levels. My pump is old now at 12years of age, I think this is the cause sometimes. Some last longer then others or quality may vary. There are alot of variables.
Paulr33 I will update you in a couple of months to see if the pump is holding up..
Cheers
before I went onto the dyno I ran NULON INJECTOR CLEANER through the car also as i use to drive around on the bottom of the tank alot which sifts all the gunk from the bottom of the tank into the injectors and is known to clog them up..It may of cleaned the fuel pump also as you put it straight into the tank.
Cliffgtst Use some injector cleaner before hand and maybe run some ethonal fuel before hand as this is also known to clean some gunk laying around in the fuel systems and engine..
    • This is what I could find on Minkara which has at least something on pretty much anything to do with the Japanese car industry. Yoshikiyo Fuji president of Fuji Dynamics memorial service review in August 2009 (at the time of his death): https://minkara.carview.co.jp/userid/380062/blog/14461568/ The Fuji Dynamics drag R33 GT-R was revived in April 2014: https://minkara.carview.co.jp/userid/781303/blog/32964763/ Fuji Dynamics drag JZZ30 Soarer: https://minkara.carview.co.jp/userid/380062/car/287607/1548806/3/photo.aspx#title Fuji Dynamics BNR34 GT-R: https://minkara.carview.co.jp/userid/300083/car/195676/609329/5/photo.aspx#title Plenty of Fuji Dynamics parts are still in use over the years on many cars, particularly the stainless steel exhausts, twin plate clutches and CPUs that can be seen in Minkara: https://minkara.carview.co.jp/search/?q=フジイダイナミクス&c=101&st=0 I also found a mention in Carboy magazine about the BNR33 GT-R drag car from 1999. It had all HVAC including A/C still fitted (A/C condenser and radiator were moved to the boot) and it ran a 9.7 sec quarter mile. Somewhat of a legend among GT-R and drag enthusiasts then and now. If you're wondering if it was a reputable shop, then yes it was.
    • Are you guys familiar with this shop? Sounds like you might have come across Fujii?
    • @Rezz our resident japan guru!
    • Hey guys I’m looking to buy an r32 gtr and it looks like the shop who’s done some work on the motor was done at Fujii Dynamic in Japan. Looking to find if anyone is familiar with this shop since there not much info I could find.    All I could find was the owner has passed away early 2000s and had previously owned a 1000hp r33 for drag racing.
    • GTR front looks good. If you don't like it, I'll swap you a rolling shell R33 for it. Give you a fresh base to start with.
