I know that changing the diameter of my tyres will result in an error in my speedo reading. I'm not sure what the "original" GTR tyre size was but I'm going to a 255/40/17. Anyone know how much "adjustment" i need to figure into the speedo?
https://www.sau.com.au/forums/topic/166324-tyres-size-speedo-error/
i'm pretty sure the standard 33 GTR size is 235/45/17, but either way it's bugger all difference. the speedo is only accurate to about 10% to begin with so i wouldn't worry too much.
Just beg borrow or steal a SatNav or similar & you'll then know exactly what you're car's doing. Anything else is guesswork
For reference, my 32 GTR is on 255/40/17's up from the factory 16's & reads roughly 7k's down at 100kph but as BB has already said that's within the factory specs
Mate, you need to work out the size based on whatever your tyre placard states, it should be whatever the stock R32 GTR size is, however sometimes it may be a bit diferent(mistakes at compliance), you're allowed to go over or under the stated tyre size rolling diameter by no more than 15mm according to rta, so keep that in mind when changing sizes. And if you like you can get your speedo recalibrated for the difference.
This is simple mate. Like T187 said the RTA will only let you go 15mm bigger in overall diameter without getting an engineer's cert.
If you want to do the calcs on any wheel/tyre combo it goes like this:
1/ Start by converting the wheel diameter to millimetres. I'll use my car as an example (R32 GTS4).
Stock size is 16 inches. Multiply by 25.4 to get 406.4 mm (yes I know the .4 is stupid but bear with me).
2/ Work out tyre height. Stock width ( 205 ) multiplied by profile ratio ( 0.55 ) multiplied by 2 = 225.5 mm
In this example 55% profile is the same as 55/100 which is 0.55. Times 2 coz tyre height is added twice.
3/ Add the wheel diameter to the tyre heights to get stock overall diameter of 631.9 mm. Cool?
I'm now running 235/40/18's. The numbers for this combo are:
Wheel: 18 x 25.4 = 457.2 mm. Tyre: 235 x 0.4 x 2 = 188 mm. Overall diameter: 457.2 + 188 = 645.2 mm.
645.2 - 631.9 = 13.3 mm more diameter than stock = no worries.
Speedo error = 631.9 divided by 645.2 = 0.9794, so at 100 k's the speedo will read 98, assuming it was accurate to start with, which it probably wasn't.
Bugger all difference though.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
