HEy guys,
I have a gts4-t and have recently got full time employment and a daily driver. So i have been modding my car......... BIG surprize! on the weekend i installed whiteface dials to the cluster and LEDS however i think i have BONED my entire dash! speedo doesn't work tacho starts at 2000 rpm and moves to 3 grand. TEmp and oil move up to the max.. etc.......... nothing works Now i did remove the needles carefully with a fork and place them back in position however should i:
1. found another gts4 cluster straight replacement - forget about white face
2. buy a gt-r cluster and pay for a rewire of the dash
3. Send it to a instrument repair
IF ANYONE has any ideas, thoughts, abuse, and something i could try FIRE away.......
Edited by RipNGrip
https://www.sau.com.au/forums/topic/166336-boned-instrument-cluster/
HEy guys,
what kind of white faced dials are we talking about it? The el ones off ebay? If so I thought they were slide on replacements to the stock dials. You wouldnt have needed to remove the needles..
well if all fails you could get another cluster off surprise surprise.. EBAY for $50 or so..
sounds like you put the needles too far in or not far enough, its very very touchy, works out to be a couple of mm between right depth and wrong. Pull the needles out again and try driving the car with cluster plugged in but without plastic cover so you can adjust it if necessary while driving. If its still rooted then take it to an auto electrician or buy a new cluster
Thanks for the input guys if u ever return to this tread to read it. It was a replacement white face not the EL ones that slide over the orginials it was from Reckless motor sports... Good dials but i definiately will try baconer idea...... sounds like a go'er
thanks again guys i will post an update - car is not in a good running state currently! :domokun: awwwwwwwwwww i miss boost! daily driver is an N/A
Yeh there was instuction and there was a disclaimer about the needle removal. Surprize surprize! the instructions stress that u need to take a photo of where the needles are! and i took note! Ie you only need to look at the fuel guage! all the rest should be at the bottom! How do u recalibrate???
1. Pull out the needle stops
2. Take car for a drive with a friend in their car and test it out at different speeds (20, 30,40 etc) until you are getting the right speed
2a. If needles are reading too high, wind past the needle stop position (you will feel some resistance, push a little past it) and test again
2b. If too low, push in the opposite direction (go clockwise till resistance, push past)
2c. If the needle movement is slow (lagging behind actual speed then catches up) then the needles are inserted too far into the circuit, raise it a little (pull needle gently) and test again
2d. If needle does not move at all it isnt inserted far enough.
3. Continue adjusting until it reads correctly
Same goes for all the gauges(speedo, fuel, oil pressure, oil temo, tacho)
Speedo - Follow what i said above
Tacho - Go by the sound of the engine or if you remember what revs you were at in a certain gear at a certain speed (eg. In 2nd gear at 40km im at around 3k rpm). Adjust till you get it correct
Oil Pressure - Get the car up to operating temp and make it so the needle sits in the right place (hopefully you rememebr where it was positioned)
Oil Temp - Same deal as above, warm car to operating temp and get the needle to read around the middle, should be a marker on gauge face where the middle/ ideal temp is
Fuel - This one i buggered myself as it has a weird resistance to it but im too lazy to fix it :rolleyes: Just fill the car up at a servo and get the needle to read full.
If your still having problems after this, pay someone to fix it.
quick update: I have taken out the speedo and pulled out the needles a little bit and tinkered with the idea of replacing the individual dials (the white plastic mechanises behind the faces/plastic diffusers). Re-calibrated the tacho as baconer suggested :P! and the tacho is now working well! however considering my skyline is broken down severly and i haven't been able to go boosting for a while i can' re-calibrate the speedo/temp/oil guage...... my skyline sounds like a rexy!!!!!!!!!!!!!!!!!!!
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
