SOLD TO SLDEWYZ
Hi All,
I'm selling my beloved bucket seats, yes they are not the real thing, but hugs just as good. Reason I'm selling these seats is because they attract too much unwanted attention from cops, bogans, car thieves, stupid kids, etc. I do not want a broken window, stolen car, or stolen seats etc. plus I need some extra money for my ski trip to NZ.
Originally purchased from JustJaps in 2004, they have been in my car since then. Rails were fabricated by Autosports Engineering for both driver and passenger side. Driver side slides back and forth, whilst the passenger side is fixed, no biggie as they both have lever recline mechanisms. Also have receipts for the seats & the rail fabrication.
For the noobs........ I know you can get new RECARO copies from JustJaps for under $400 with universal rails to fit the bin, universal rails are rubbish, they bolt up to nothing, so do not comment on the price, if you think you can get them to bolt in be my guest and I do not want to hear your stupid uneducated comments. Noobs, dreamers, and keyboard warriors certainly unwelcome.
Will only fit S13/S14/S15.... If bolted to a skyline only 3 of the bolts will line up and the 4th one will be out of place. I suppose it could be just cut and re-welded, but that is entirely up to you.
Seats still currently installed in car as per photo.
PRICE: $500 for the pair includes rails that fit, will not separate rails or seats.
Edited by johnnilicte
https://www.sau.com.au/forums/topic/166345-sold-sold-sold-sold/
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
