Hey, I just bought a HR31 GTS that I've had my eye on for a while, but sadly it was defected a few owners ago. My goal is to get the canaries taken off (yes, canaries, it was re-defected while on a day pass, the bastards), and the car registered.
I'm in Strathalbyn, SA, so can take it to the Murray Bridge Inspection Station, which AFAIK means no emissions testing. It has a Haltek computer, but I'm not sure of the model, as its nicely stashed under the dash.
The things that are currently on my to-do list are
- Tie-Rod Ends (worn, and new ones sitting in the boot)
- Mount Pod FIlter securely (or do I have to try to fit an air box in there??)
- Sort out where to plug the tacho cabling into the Haltek
- Sort out a suitable speedo adaptor for the R33 Box (Going to try the Navara drive from this thread first)
- Perhaps dummy wire a stock computer (or another computer that looks the same, ie. S13 computer) so that even if yanked on, the wiring will stay in place (will this work? or do they test for connectivity?)
- get a rear windscreen wiper
- sort out various minor wiring and globe issues
Aside from these, I have a set of pads ordered, it has good tyres, handbrake works, factory steering wheel, correct offset and stock-size rims, Regency-proven Trust Exhaust, the number plate is back on the correct (right-hand) side.
Is there anything else that anyone thinks I may need to look at/get checked out before attempting the inspection?
Cheers
Tristan
Edited by guska
https://www.sau.com.au/forums/topic/166349-defected-hr31-roadworthy/
re: gearbox
You need a 32 GTR Speed sender, and put the RB25 gear from its sender into it.
Then your speedo will hook up/work.
The Navara one won't work? I already have it ordered (forget exactly how much, but quite cheap, as I buy a lot from the guy).
What sort of $$$ would I be looking for a 32 GTR sender? Even 2nd hand is fine. I was told about a "RB25 adaptor for a cable speedo" which can usually be obtained from Kensai Automotive for around $300, but they haven't seen one for a few months, and I would like to be able to get around it a bit cheaper. The guy I bought the car from had one in it, but used it in his 32 GTS-T when he put a 33 box in that.
On another note, I actually took it for a decent drive today, and it's brutal!
SOmething I just thought of, it has a 2-way LSD, which 'hops' the inside tyre during full-lock turns, will this be a problem at inspection? I never thought to watch what the guy did when I sent my old UC Torana for inspection just to see how long he could make the list.
what about your shocks and springs... is it sitting at the correct ride height...
and what are your seat belts like... are they frayed at all?
also is there and structural rust in the car.........
any of these things and they will have a hissy fit and car wont get thru........
It's sitting at legal ride height (edit: I think), but it's stiff. Seat belts are all good, no rust at all! I'll take some pics either today or tomorrow, when I go and do the tie-rod ends. The car isn't at home, it's at a mates place who has a shed and is closer to Mt Barker where any work I can't do will be done, so I don't get to see it every day yet.
Edited by guska
GTR sender is around $150 second hand. Thats what i paid for mine.
The Navara one isnt a direct fit. You need to fark around with the gear wheel or something.
And if you dont do it right, its stuffed
Hence i just used a GTR one. nice and easy
I'll give the Navara one a crack first, since I have already ordered it (typical me, jumping in before having all the info). SO the GTR one is a simple case of swap the gear on the other end, bung it in, screw the cable in, and watch how fast the needle moves yeah?
Actually, can anyone here tell me what the legal ride height for a HR31 is? I am told it's legal, it looks alright, but so did my mate's 32, and it was pinged for too low. Ride height is measured from the top of the guards to the centre of the axle/hub yes?
Edited by guska
  • 3 weeks later...
  • 7 months later...
Sorry for not getting back to this thread sooner, but I was without internet for a while, then completely forgot about it.
I still have the coupe, still defected.
It has the silvertop RB20DET in it, with the RB25 5-speed.
I have now moved to NSW, and am about to go and retrieve my car from SA in early Feb.
My new question is, do I need to clear the defect in SA before sending it for a rego inspection in NSW? Or does the inspection in NSW make the SA defect redundant? I have been advised that this is the case, but I just want to be sure, and the RTA were of little to no help.
has it run out of rego in SA??
if so i'd say to rego it in NSW you would have to do what ever is required to rego a new car there?
i've, in the last 2 months, bought a car from VIC and rego'd it here in QLD, the rego had run out 2 days before i got it rego'd here and had to just get a road worthy cert and rego it as a new QLD car.
i hear the NSW requirements are pretty tuff though. you might have to get what ever the problem in SA was fixed anyway....
Was defected in SA...
The problems are fixed, it is basically just the ECU and tyres (3rd gear brake job during which I lost my licence) holding it back from SA rego. Along with whatever else they find. As far as I can find out, aftermarket ECUs are alright in NSW, as long as all the emissions gear is hooked up... hmmm, might have to 'hook up' the AFM... and theres no gaping holes in the loom.
Oh, and the Navara speedo sender worked a treat! Just bunged it in, and now it reads 10km/h under, so I better fix that at some stage...
Oh, and yes, the rego is well and truly expired, 2004 I think, if not earlier.
Edited by guska
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
