  • Replies 47
:P Oh Maz...Glad you are ok
Sorry to hear ..but doesnt look that bad. It definatly could of been worse :)
Did you put the new suspension in?
Hope you get her all fixed up *hugs*
Jess
yeah jess coils were in, setup on 8 steps past soft, and yeah could def. be worse
Yeh steve not a good thing to happen to anyone! Hope your daughter wasn't in the car! she would have been shook up a bit!!
naw she wasnt luckily as its not nice having to calm an child down after that
thanks for well wishes
im thinking just getting it fixed by someone like chips and dents or @ least seeing what they think
typical whore response...
hey madaz, u can get airduster stuff from officeworks or any place like that... all u do is turn the can upside down and bingo, liquid CO2... use in a well ventilated area.
Bit rich coming from you pauly (typical whore response) King of spam whoring LOL
Sorry to hear about your car Steve by the way
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
