  • Replies 47
yeah
had it on the hoist today and there seems to be absolutely nothing wrong :) phew
and lol on unrelated news been pre approved for another 2.5g on my credit card but wont be taking it up but i thought it was funny
/edit after watching your sig a few times i now know what i did wrong :worship::)
Edited by Madaz
yeah
had it on the hoist today and there seems to be absolutely nothing wrong :( phew
/edit after watching your sig a few times i now know what i did wrong ;):worship:
YAY!!! :worship: Glad to hear only cosmetic :(
Yeah dam credit cards :P
credit cards are crazy, i could never get one when i had 20 grand in the bank and a full time job.
But as soon as i got a personal loan they kept offering them to me.
Yep keep doing that to me also...1 is enough :laughing-smiley-014:
should see the F6 that came into work today, he went off and hit a tree in the wet weather!
front corner is badly smashed up, try and get a photo of it tomorrow
moral of the story ford drivers shouldn't turn off traction control in the wet
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
